01' V10 Heads upgrades?
Had my 2001 v10 superduty in the shop for a blown plug repair.
The shop screwed up this repair and burnt a valve. They are now paying for a bigger shop to remove the cab and pull BOTH heads and send them in. I just curious if anyone had any recommendations on any upgrades that would be best to do now while the cab is off and while the heads are in the shop. Truck is 6" lift on 35's, king cab long bed. Has K&N filter. future ups are SC Tuner and Exhaust. Thanks! :oval :-drink :oval |
Edit, the are paying for the heads to be pulled, just curious if there is anything I need to watch out for or I can have done in addition to.
thanks |
Definitely have the exhaust manifold studs replace or upgraded. I read on this forum about a guy that had larger diameter studs installed. I can't vouch for the results. But it's intriguing. At the very least you should have them ALL replaced with new.
Along the same thoughts- get your exhaust manifolds checked with a straight edge, and lightly machined if they're out of spec. I suppose it can't hurt to get the straight edge on the head port surface also. All these suggestions are obviously related to the problem with the studs. As far as other improvements- you could check into the "usual" performance improvements like machining the heads for increased compression, replacing camshafts for better breathing, increasing the port size, etc. but honestly in my years on this forum I haven't seen anyone actually DO those things. |
If they are replacing at least one of the heads, try to go for the longer-thread head from 2003+ model year.
Other than that, there is no real "upgrade" for those heads. Porting, whatever. HOWEVER, a set of headers would really wake that thing up }> |
Originally Posted by Im50fast
(Post 17217515)
Along the same thoughts- get your exhaust manifolds checked with a straight edge,. Though I was meaning more about power ups, exhaust bolts are a issue on these things so I've read. Thanks! |
Originally Posted by Krewat
(Post 17217969)
Other than that, there is no real "upgrade" for those heads. Porting, whatever. HOWEVER, a set of headers would really wake that thing up }> THANKS! |
Why lift the cab off to pull the heads. When I had a shop do my heads..........it took them about 3 hours to pull them both without pulling the motor or lifting the cab. Had all valves replaced in my heads plus all steel inserts for the spark plugs....plus ne valve springd and both heads resurfaced.
Originally Posted by CPaulsen
(Post 17224746)
No clue, it is on the other shops dime. |
Originally Posted by Sinntax
(Post 17221601)
Great suggestion....
With the cab off, should have plenty of room to install new gears! :)
Especially with 35's on a 6 inch lift. |
Originally Posted by truckfella
(Post 17230388)
If I had to pull mine I'd at least smooth and polish up the combustion chambers on the heads. Maybe even try a heat barrier coating. Goal is to help prevent detonation and carbon buildup in the future.
UPGRADES, yes there are some upgrades you can do.
Valves are the same as in a 2V V8 modular motor. So you can put 1 or 2 mm larger valves in it. That will make it breath a little better. You could put custom cams in it. Comp cams will custom grind them I think as they sell V10 cam cores. I would put premium valve guides in it and enlarge and radius oil return holes. |
Originally Posted by rock2610d
(Post 17235837)
Valves are the same as in a 2V V8 modular motor. So you can put 1 or 2 mm larger valves in it. That will make it breath a little better. You could put custom cams in it. Comp cams will custom grind them I think as they sell V10 cam cores. I would put premium valve guides in it and enlarge and radius oil return holes. And id be very leery of changing the oil return holes. Unless there is a known issue I haven't heard of. It's a great idea for racing, where rpm is constantly high, but changing a street vehicle lubrication design is risky. |
Sorry I thought it's a given that if you put larger valves in the seats would need enlarged too.
Anytime you can get oil back to oil pan faster it's better. |
