4high vs 4low
Old Jan 9, 2021 | 08:40 PM
  #31
scraprat's Avatar
scraprat
Top Answer: 5
Sure use it reverse. I often do when getting my 5th wheel in to some boondocking location. As been said less stress in the system.
Old Jan 9, 2021 | 08:42 PM
  #32
FordF250#1's Avatar
FordF250#1
Originally Posted by Kellem
You can use 4w-lo or 4w-hi in reverse in boat launches or recovery with wheels straight, do it all the time.
Ok thanks.
Old Jan 9, 2021 | 09:22 PM
  #33
LMychajluk's Avatar
LMychajluk
Originally Posted by JeepPuller
4 lo is for extreme traction and power. You are very limited in 4 lo. Speed of any kind is not really possible.....
Lol... I was reading the manual earlier, and saw this:
In 4L (4X4 low), the electronic locking
differential will automatically
disengage at speeds above 62 mph
(100 km/h) and will automatically
reengage at speeds below 56 mph
(90 km/h).
Edit - also, the manual actually recommends switching to 4L if you get stuck going up a hill, then backing down. So, no problem in reverse.
Old Jan 10, 2021 | 06:56 AM
  #34
Crotchety Ford truck only's Avatar
"In 4L (4X4 low), the electronic locking
(90 km/h)."
You sure about that ?
Old Jan 10, 2021 | 07:23 AM
  #35
scraprat's Avatar
scraprat
Top Answer: 5
(90 km/h)."
Right here on page 220 of the 2020 owners manual it states it.
ELECTRONIC LOCKING
DIFFERENTIAL (IF EQUIPPED)
Note: The electronic locking differential is
for off-road use only and is not for use on
dry pavement. Using the electronic locking
differential on dry pavement will result in
increased tire wear, noise and vibration.
The electronic locking differential is a
device housed in the rear axle that allows
both rear wheels to turn at the same
speed. The electronic locking differential
can provide additional traction should your
vehicle become stuck. You can activate
the differential electronically and shift it
on the fly within the differential operating
speed range. The differential is for use in
mud, rocks, sand, or any off-road condition
where you need maximum traction. It is
not for use on dry pavement.
The following conditions will affect the
electronic locking differential:
• The electronic locking differential will
not engage if your vehicle speed is
above 20 mph (32 km/h) in 4x2, or 4x4
High modes.
above or 56 mph (90 km/h) in 4X4
Low.
• The electronic locking differential may
not engage if you press your
accelerator pedal during an
engagement attempt. A message may
display in the instrument display
guiding you to release the accelerator
pedal.
• In 4x2, and 4x4 High modes, the
automatically disengage at speeds
above 25 mph (41 km/h) and will
automatically reengage at speeds
below 20 mph (32 km/h).
• In 4L (4X4 low), the electronic locking
(90 km/h).
• The AdvanceTrac system has the
ability to take over control of the
electronic locking differential and
disable it during driving maneuvers
when necessary.
When you switch the system on, if you do
not meet the required conditions for
electronic locking differential activation,
the instrument cluster will display the
appropriate information guiding you
through the proper activation process.
Activating the Electronic Locking
Differential
Note: Do not use electronic locking
differential on dry, hard surfaced roads.
Doing so will produce excessive noise,
vibration and increase tire wear.
Note: If the electronic locking differential
has difficulty disengaging, release the
accelerator pedal and turn the steering
wheel in the opposite direction while rolling.
Old Jan 10, 2021 | 07:51 AM
  #36
ELECTRONIC LOCKING
High modes.
Low.
pedal.
(90 km/h).
when necessary.
Differential
Is it me, or is that completely contradictory to itself and the real world. 62 mph in 4 low and 90 other contradictions............Some one screwed up.
Old Jan 10, 2021 | 07:55 AM
  #37
Desert Don's Avatar
Desert Don
Well, sir; quite a few years ago I was riding with a guy that had a 75 or 76 F150 (don’t know exactly what gearing he had) and he had that doing about 65-70 in 4L!!!
The old 390 was wound pretty tight though! As a side note, there was just a little adult beverage involved at the time (I DO know better now)! And we WERE a long way from any public roads.
Old Jan 10, 2021 | 08:54 AM
  #38
scraprat's Avatar
scraprat
Top Answer: 5
I thought the same. I do know when I lock mine in it will disengaging at ths low mph (20 mph +/-) and flash the message on the display when disengaging and reengaging.
bulla
Dec 29, 2010 12:29 PM
JTreibs
2009 - 2014 F150
Jun 17, 2009 08:52 PM
Musicman250
Offroad & 4x4
Jan 11, 2004 10:39 PM
joe computer
1983 - 2012 Ranger & B-Series
Nov 5, 2003 08:03 PM
AlexDeLarge
Apr 29, 2003 11:21 AM
