1996 Backup Lights Not working
Old May 24, 2017 | 08:16 PM
death2zeus's Avatar
death2zeus
Exclamation 1996 Backup Lights Not working
I have a 1996 F150 4.9L with a manual transmission. The backup lights have not worked since I have owned the truck. In my attempt to diagnose the issue I found a wiring issue in my transmission harness, bypassed the transmission switch, confirmed that the switch wires have power, checked the fuse, and confused myself about the pin-out off the rear connector. I can't seemed to find a pin out of the rear connector. The connector is the same one used for the brake lights, and is an 8 pin connector with only 6 pins. I have 3 12v wires in the connector, and what appears to be 2 ground wires. I have one wire that has neither a ground nor power. During the testing I had the ignition on and the transmission switch connector jumpered. I jumpered the connector such that I wouldn't have to keep it in gear, and to take what could be a faulty transmission switch out of the equation. I haven't checked the rear taillight harness for continuity to the backup lights, and do not think its important until I have the connector diagnosed. I do not know where to go from here.
zamman61
Aug 18, 2016 11:47 AM
kindred58
1983 - 2012 Ranger & B-Series
Mar 3, 2014 06:08 PM
77f250weos
Aug 15, 2013 12:26 AM
SomePunk
Jan 26, 2008 08:58 PM
77300i6
15
Oct 12, 2007 08:06 AM
