OT somewhat Frame coating help
Old May 24, 2017 | 06:54 PM
49f3dls's Avatar
49f3dls
I hope someone can help this forgetful old guy. A friend has a boat in SC the trailer is aluminum but has 4 galvanized cross members. The salt water has pretty well destroyed them and he has new ones to put in. My question is would it be wise to coat them with "POR 15" (part of my problem is I can't remember if that is what it is called) or would the salt water just eat it away? If that doesn't work does any one have any other ideas? Thanks Dave S
Old May 24, 2017 | 09:04 PM
drptop70ss's Avatar
drptop70ss
I know POR15 does not like smooth surfaces, so not sure if it would stick to fresh metal or not without roughing it up. Not sure it would stand up to salt water, I would ask the manufacturer.
Old May 24, 2017 | 09:24 PM
49f3dls's Avatar
49f3dls
Thanks Dave. I just checked internet and it does say good for marine use but nothing about salt water. Hopefully someone may know. Thanks again for confirming it is called POR15
Old May 24, 2017 | 09:46 PM
seaves46's Avatar
seaves46
If the new cross members are galvanised , I don't see the need to paint them .
If they have had holes drilled in them then been hot dipped in gal , they should be well enough protected already .
Old May 24, 2017 | 10:04 PM
49f3dls's Avatar
49f3dls
Scott the old ones were galvanized and they were really in bad shape. I didn't think that would happen. That is the only reason I thought of using this. Maybe he is wrong and they are just plain steel.
Old May 25, 2017 | 04:15 AM
petemcl's Avatar
petemcl
If they are galvanized then they are probably steel. Hopefully they are U channel and not boxed. The issue with fully boxed cross members is that it is hard to coat all the nooks and crannies inside. I had a boat trailer that I used to launch in salt water all the time. The paint was peeling when I bought it so I used a professional sandblasted to strip it. Then I immediately spray painted it with a red, water soluble rust resistant paint/primer. It had no gloss to it but in the 10 years that I owned it I never had any rust on the frame. But it had U channels not boxed.
The other issue is if you store the boat and trailer at a boatyard the salt air will really eat through most anything. I always thoroughly rinsed my boat and trailer with fresh water after use and stored it at my house that was 15 miles inland from the launch ramps that I used.
Old May 25, 2017 | 08:04 AM
CharlieLed's Avatar
CharlieLed
I prefer KBS Rust Seal over POR15 for a number of reasons but here is a link to their website https://www.kbs-coatings.com/rustseal.html so that you can determine for yourself if this product will meet your needs.
Old May 25, 2017 | 08:32 AM
49f3dls's Avatar
49f3dls
Thanks guys. I will pass the info on. He bought it used and the old ones were boxed. The new are u channels. He does store it about 10 miles inland and is careful to rinse it. The damage was done before he got it. Thanks again.
Old May 25, 2017 | 08:37 AM
joezzz's Avatar
joezzz
POR-15 is the right product. I can tell you that I have used to coat the exterior of an aluminum fuel tank that I have in a sailboat, its been there 15 years.
As always, it's all in the prep. Sanding to scratch the surface followed by following the instructions.
Old May 25, 2017 | 08:50 AM
pweng1's Avatar
pweng1
I would put a coat of por 15 or its equal on it just to seal it from the air. The products they have nowadays can make things last a lifetime.
Old May 25, 2017 | 12:13 PM
49f3dls's Avatar
49f3dls
Thanks guys. He is looking for POR15 in SC as I write this. Going to rough sand the braces and put it on before he assembles to trailer then do touch up. Again thanks for your help. Dave S
CountryD
6.7L Power Stroke Diesel
22
Apr 1, 2013 11:11 AM
ReAX
Mar 15, 2009 08:12 PM
Steina
Appearance & Dress-Up
Jan 29, 2005 02:49 PM
rick88
34
Jun 14, 2004 04:34 AM
Cliford
Dec 6, 2003 09:54 AM
