help needed desparately
Old May 27, 2017 | 01:53 PM
  #31
jacknewt's Avatar
jacknewt
need help desperately
Thanks for all your help. If I get it running will let ya know.
Old May 27, 2017 | 02:55 PM
  #32
rla2005's Avatar
rla2005
Originally Posted by GoinBoarding
confirm if 45 psi KOEO fuel pressure is adequate for an 87' 4.9L?
45-50 PSI is spec. 45 PSI is plenty under idle condition.
Old May 27, 2017 | 11:09 PM
  #33
Lead Head's Avatar
Lead Head
A possible cause could be a failing coolant temperature sensor, or failing TFI module/Ignition coil.
Old May 27, 2017 | 11:38 PM
  #34
one_bolt_short's Avatar
one_bolt_short
Could you explain how/why a coolant temp sensor would affect the fuel delivery? I had issues with a hot restart, replaced mine, and all is good. I erroneously thought it was an ECM shutdown, but was informed the ECM does not have this capability. So, how does the coolant temp sensor fit into the equation? I'm not doubting one bit it does, I just want to know how it does. Thanks.
Old May 28, 2017 | 12:12 AM
  #35
Lead Head's Avatar
Lead Head
The coolant temperature directly controls temperature-related fueling. Cold engines need more fuel than hot engines.
jgrimm6
Jun 30, 2016 10:36 AM
FX4-350
26
Mar 9, 2014 08:03 PM
cyclist7531
1983 - 2012 Ranger & B-Series
Apr 29, 2011 11:22 AM
X-Power
Mar 8, 2006 11:49 PM
torquemeister
Mar 14, 2003 02:47 AM
