early 260/289
Old May 23, 2017 | 10:06 PM
jfb50's Avatar
jfb50
early 260/289
does any one remember the ford part number for the plate between the motor and the flywheel for 5 bolt bellhousing stick fairlane /mustang
Old May 28, 2017 | 11:53 PM
baddad457's Avatar
baddad457
Best way to locate that is hit up the classic Stang venders. Any of them should have that in stock. Try Mustangs Unlimited.
Old May 29, 2017 | 12:16 PM
jfb50's Avatar
jfb50
thank you baddad i think i have correct one coming, i hope
Old May 29, 2017 | 12:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jfb50
does any one remember the ford part number for the plate between the motor and the flywheel for 221/260/289 5 bolt bellhousing stick Fairlane/Meteor/Falcon/Comet/Mustang?
C2OZ-7007-C .. M/T Engine Rear Cover Plate / Obsolete
1962/63 Mercury Meteor; 1962/64 Fairlane; 1963 1/2/1964 Falcon/Comet; 1965 Mustang before production date 8/23/1964.
No Ford dealer or obsolete parts vendor has any.
Old May 29, 2017 | 02:05 PM
xlt4wd90's Avatar
xlt4wd90
It's a large sheet of steel cut out into a particular shape and holes in it. If it's not being made by any sheet metal stamper, or not available on Ebay, it's not impossible to make one.
Old May 29, 2017 | 11:15 PM
Beanscoot's Avatar
Beanscoot
It has to be made very carefully however, since it helps locate the starter pinion's engagement with the ring gear.
It's one of those pieces that people usually threw out when they saved an engine or a transmission, unfortunately, so there is a relative shortage of them.
Old May 30, 2017 | 12:26 AM
xlt4wd90's Avatar
xlt4wd90
Wouldn't the starter mount bolt holes on the bell housing put the starter at only one place? I would use the bell housing to make a template to cut the plate, since that's what the plate is for, covering the bell housing. I've seen some applications where the depth of the stater set using shims.
Old May 30, 2017 | 11:22 AM
jfb50's Avatar
jfb50
NumberDummy thank you for taking the time to look it up your help is greatly appreciated. I found a new old stock one on ebay with part number C2OZ-7007-C and ordered it. jfb.
Old May 30, 2017 | 12:24 PM
Beanscoot's Avatar
Beanscoot
Starter location
I think the bolts hold the starter within about a sixteenth inch of its final location, while the plate locates it precisely. Kind of like the bellhousing bolts and dowels.
But I haven't investigated this carefully, so I can't say it with authority.
Old Jun 8, 2017 | 11:17 AM
jfb50's Avatar
jfb50
it finally arrived now i can put it together
Old Jun 8, 2017 | 11:33 AM
jfb50's Avatar
jfb50
i am tring to put these two together
Old Jun 8, 2017 | 03:13 PM
Beanscoot's Avatar
Beanscoot
260-4V
That looks good.
I had a 260-4V on my Fairlane some years ago. I installed a stock iron intake with a big block Autolite 4V carb, but switched to a 370cfm (sic) Holley 4 barrel because I wanted better low rpm power.
Old Jun 8, 2017 | 03:34 PM
xlt4wd90's Avatar
xlt4wd90
I recently did nearly the same thing:
https://goo.gl/photos/MpmAvSihJNqXUjvV7
The toploader rebuild is near the bottom. I should have painted mine as well; maybe later, some day...
Old Jun 9, 2017 | 04:30 PM
baddad457's Avatar
baddad457
It's not the bolts holes that are the important feature here, but the large round hole the starter nose fits into, this indexes the starter teeth to the proper distance from the ring gear teeth to insure one does eat up the other over time. The two short pins set into the rear of the block also serve to orient that big hole to where it needs to be. You'll notice those pins to the plate are a tight fit, unlike the bolt holes
Old Jun 27, 2017 | 12:12 PM
jfb50's Avatar
jfb50
getting closer
