This cannot be good!
Old May 23, 2017 | 02:08 PM
Dman130's Avatar
Dman130
Went to change the transmission fluid in my new/used truck and look at what is not a Cracker Jack prize at the bottom of the pan. I realize this is a really bad indication that my tranny is about to fail, and that nobody has a crystal ball, but am asking the question if I continue to drive it (as there is no obvious problems currently) till the it fails, am I compounding my soon to be $2000 repair bill? I am told it is a "center snap ring" and failure is inevitable, this is coming from the guy that quoted the repair so I get that he wants the business but asking the question here is free! FYI.. I don't tow with it, drive 30 miles a day in light city traffic and will have my 86 road ready in a week.
Old May 23, 2017 | 02:46 PM
CountryBumkin's Avatar
CountryBumkin
Well the good news is that the plastic piece in the pan is normal (just a plug used during assembly that they push into pan when installing the dipstick/filler tube) - so that's one less piece you need to worry about.
Old May 23, 2017 | 03:10 PM
Franklin2's Avatar
Franklin2
More news, you are the first one in there since the truck has been built. Don't know about the other "snap ring" piece.
Old May 23, 2017 | 03:22 PM
CountryBumkin
Get a price and warranty from the local guy.
When I worked for city - we bought remanufactured transmissions from Jasper (they will have a shop in about every major city). They were good quality rebuilds and have a 3-year 100,000 mile warranty. Remanufactured Transmissions | The Jasper Process
Your AOD is not much for performance - maybe you don't need it beefed up. But if you were to pay the $2000 you mentioned (which is twice what a Jasper tranny will cost you) you could get a "built" transmission from Broader Transmission AOD - Broader Performance
Old May 23, 2017 | 05:57 PM
FuzzFace2's Avatar
FuzzFace2
I found if you do the R&R and they do the rebuilding it is a lot cheaper.
I would try and get your other ride working asap then get this fixed when you want.
I don't think I would drive it more than I had to because if more gets broken inside or the case it's self could run more $$ than he gave you.
Just my .02
Dave ----
Old May 23, 2017 | 07:17 PM
reamer's Avatar
reamer
2000? that's cheap!
Old May 23, 2017 | 07:43 PM
cadunkle's Avatar
cadunkle
Looks like a snap ring. The plastic piece or normal, dipstick plug the just push into the pan when installing the dipstick. I would plan to pull and rebuild soon. Get your other vehicle working and then do this. $2000 is insane, a rebuild kit is $200-$400 and it ain't rocket surgery.
Old May 23, 2017 | 09:02 PM
rowdyredneck's Avatar
rowdyredneck
Judging by the size I'm guessing its the snap ring above the center support, number 883 in the diagram:
Old May 24, 2017 | 08:48 AM
Dman130's Avatar
Dman130
Based upon rowdyredneck's diagram posting, and knowing my limitations, me, myself and I am not up to the challenge of a repair/rebuild. If your in Wisconsin next week, I'll supply the pizza and beer..........
Old May 24, 2017 | 08:51 AM
Dman130's Avatar
Dman130
Part # 883 looks correct, the other 2/3rd's is hanging on my what I don't know, so I'm gonna get on getting my other truck running ASAP. I can tackle these decisions without the pressures of how I am going to get to work, thanks for the info.
Old May 24, 2017 | 08:53 AM
Dman130's Avatar
Dman130
The Jasper idea may be just the ticket, I gotta look into the complexity of an R R.
Thanks for the input
Old May 24, 2017 | 08:59 AM
Dman130's Avatar
Dman130
Talk about differences of opinion, "2000 is cheap" verses for that money I could get a "built" unit. I know my mechanical abilities, so there is something to be said about letting the guys that do this for a living take care of this. It would be about a 5 to 7 hundred dollar savings, which is clearly a lot of money but making a mistake could be just as costly. Gonna do some more research, thanks for your input.
Old May 24, 2017 | 10:35 AM
Wagonboy's Avatar
Wagonboy
That snap ring is not needed during normal use. It just holds the center support in place during the assembly of the transmission.
Old May 24, 2017 | 12:51 PM
Dman130's Avatar
Dman130
So there is hope it'll hold for longer than expected ?! Not planning any long trips or towing, so this may be great news.
Old May 24, 2017 | 02:14 PM
Franklin2's Avatar
Franklin2
I asked about this at my local tranny shop. It would only save me $100 and they would not warranty the trans. I asked why and they said there was no guarantee that I would get the radiator cooler clean enough, and any dirt in there would ruin the rebuilt trans. They had special cleaner stuff and a certain method they used to clean it out.
