Dash Cam Wiring
Old May 23, 2017 | 06:57 AM
Stevem4134's Avatar
Stevem4134
Dash Cam Wiring
Hi,
I am looking to install a two camera dash cam system to my 2011 F-250, 6.7L Diesel, Crew Cab. I have searched this site, the web and youtube for pictures or videos that can help me route the wire from the rear dash cam to the front cam.
The shortest route is under the headliner. I know that I can remove the door trim and have access to the area under the headliner but how do I get around the side curtain airbags in the truck?
Can I push the rear cable above and behind the side curtain airbags or do I need to remove the headliner?
Anybody have any other cable routing ideas or pictures?
Old May 23, 2017 | 12:09 PM
Deuce40s's Avatar
Deuce40s
I wonder if there's enough room for a fish tape between the headliner to go front to back? If not, I'd run the wires down the pillar to the floor, then back up at the A pillar. I don't like messing with the headliner because I can never get it to fit right again.
Old May 23, 2017 | 12:54 PM
shortride's Avatar
shortride
I've got a Street Guardian SGZC12SG dash-cam in my truck. I hate wires and will do almost anything to prevent having to buy a wired product. Unfortunately there aren't any wireless dash-cam that I know of so I will make do with what's available. I too had to route the 12 volt power wire around the headliner and down the A pillar on the passenger side to the 12 volt power plug.
Old May 23, 2017 | 10:45 PM
Painted Horse's Avatar
Painted Horse
It's been over 2 years since I installed mine, I'll have to go look tomorrow.
But I know I tucked the wires up into the front of the head liner, over to the passenger side and 1 wire down the column and into the fuse box by the passenger foot well and the second wire I continued to the back window for the rear facing camera. All you can see are a couple of inches of wire just above each of the two camera, like in the photo above
Old May 24, 2017 | 03:46 PM
my_crib_too's Avatar
my_crib_too
On page1 of this thread that I created some time back, it shows how to drop the headliner for installation of some lights. Dropping the headliner should be about the same process for installing some wires. Pretty simple process.
https://www.ford-trucks.com/forums/1...ts-thread.html
bruce....
Old May 25, 2017 | 03:19 AM
tmangus's Avatar
tmangus
Exclamation Wiring next to curtain airbags
I would go across and down to floor and into door sill plates. Avoid putting wires next to airbags. Bad idea. Especially since the airbags deploy with force and anything in close could cause a malfunction or become a projectile safety first
Old May 28, 2017 | 08:29 AM
Stevem4134's Avatar
Stevem4134
tmangus,
Looks like I will be routing the cable the way you advise.
Thanks to all for your input.
Mayne Man
6.7L Power Stroke Diesel
39
Mar 31, 2019 04:36 PM
sailkat
Jan 9, 2018 06:26 AM
54LFL
Nov 18, 2017 06:57 AM
LiquidSteam
Jul 1, 2017 12:23 PM
Stevem4134
May 20, 2017 07:42 AM
