Bliss and towing question
Old May 22, 2017 | 08:44 PM
lotsofords's Avatar
lotsofords
So I use the display and set up my trailer(s) with owners manual in hand. It is within the size limitations for BLISS (26' long, 8' wide). I have no problem clicking the OK's. I am in tow/haul mode. Seems like all should work. When all said and done, no BLISS.
What am I missing?
Old May 22, 2017 | 08:57 PM
jm-bc's Avatar
jm-bc
Is your trailer wiring properly configured and connected to your truck? Then test the lights. The systems determine if a trailer is present based on the connection.
Old May 22, 2017 | 09:01 PM
lotsofords's Avatar
lotsofords
yes it knows the trailer is there, all lights work as to the trailer brakes. Also, two different trailers, same problem. Everything else is working. I have to be missing something in the set up
Old May 22, 2017 | 10:11 PM
wb6anp's Avatar
wb6anp
I read with the trailer blis wont work till your above 6 mph I think, I saw, when I set mine up that the blis was off, didn't feel like connecting and taking it out of storage to test./
Old May 23, 2017 | 06:25 AM
troverman's Avatar
troverman
I'm running an 8.5' wide trailer, works fine with BLIS. In fact, I set it up for one trailer of a different length and it still works fine on this trailer. What makes you so sure you have no BLIS? Is the little disabled icon illuminated?
Old May 23, 2017 | 09:02 AM
lotsofords's Avatar
lotsofords
yes the disable icon is illuminated and no lights in the mirrors
Old May 23, 2017 | 03:03 PM
Johnpsz's Avatar
Johnpsz
when you selected the type of trailer did you select gooseneck or 5th wheel? Bliss gets turned off for those "type" of trailers. I cannot advise something possible dangerous as there may be a reason Ford did this, but I just programed my 5th wheel a standard trailer. I haven't gotten over 100 miles to start towing it yet, but just testing it the disable icon didn't appear. Now, when I go to tow the 5er, I might find I get false readings due to the overhang of the trailer, but we'll see when that time comes...
Old Jul 7, 2017 | 10:56 PM
kho6658's Avatar
kho6658
I know this is an old thread but did you ever resolve the Bliss issue? Mine was working fine until this last trip. Left Austin Texas and drove to North Carolina, it was working fine. From North Carolina to Florida it stopped working. Keeps telling me I don't have a conventional trailer setup. Nothing has changed with my trailer setup. Tried deleting and re-adding, still, doesn't work.
Old Jul 8, 2017 | 08:20 AM
harley1756's Avatar
harley1756
I have the same issue. I've pulled my travel trailer a few times and it worked great. The last trip home I had a message " no conventinal trailer connected" The trailer set up had not changed. I changed the setting to fifth wheel and back to conventinal and it made no difference.
Old Jul 8, 2017 | 10:57 AM
54LFL's Avatar
54LFL
Also - my Travel Trailer is 36' 9"...is ford's limitation (is it 33') real, or is anyone getting it to work with longer trailers?
Old Jul 8, 2017 | 10:58 AM
livkot's Avatar
livkot
I experienced issue also. In the trailer menu all was set and selected correctly yet no bliss. In my case I found the menu to the full right, settings or some language like that, there was a check box selection for trailer blind spot. This arbitrarily unchecked itself and still does. Check that setting.
Old Jul 8, 2017 | 03:13 PM
kho6658's Avatar
kho6658
Yep I tried that also and made no difference.
Old Jul 8, 2017 | 03:16 PM
kho6658's Avatar
kho6658
When in the trailer settings, blind spot is off and you can't turn it on because there are no conventional trailers attached. Was hoping someone had found an answer to the problem but I guess it needs to go to the dealer.
Old Jul 9, 2017 | 11:08 PM
prof nomad's Avatar
prof nomad
Make sure that the trailer bliss is checked off in the main truck setting section of the display.
Old Jul 10, 2017 | 07:07 AM
kho6658's Avatar
kho6658
Thanks, I just checked mine it is was unchecked. Drop my trailer off at the dealer for some warranty work so can't check if that will fix it but hopefully, that was the problem. Thanks for the help.
