Transmission issue?
Old May 22, 2017 | 08:27 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
I'm pretty sure you need that for your converter to lock up correctly
Old May 22, 2017 | 11:26 PM
garrettsf250's Avatar
garrettsf250
well I'll check it out tomorrow and let you know. Thanks for the input!
Old May 23, 2017 | 06:14 PM
garrettsf250
so went to use the cruise control today coming home from work and it's not working. That have anything to do with the converter?
Old May 23, 2017 | 06:41 PM
Shawn MacAnanny
Yes, because you installed LED lights and have no 3rd brake light. You're getting stray voltage through the 3rd brake light wire that tells the computer to unlock the converter and also cancel the cruise control. I know on my truck, 3rd brake light was out and with the lights off at night you could very faintly see my LED brake lights still lit on the tow truck body. That's how i knew i had stray voltage on the brake wire. I dont know why i had it but it caused converter issues and i know when i replaced the blown 3rd brake light it went away. It's been fine for 15,000 miles now. So i would try putting a working non LED bulb in your 3rd brake light. Cruise not working and converter not locking usually means your brake signal is telling the truck its stopping
Old May 23, 2017 | 06:52 PM
garrettsf250
all for for a freaking brake light really..? Lol well thank you very much I'll give it a try and I'll come back to let you know if it worked or not. Thanks!👍🏼
Old May 24, 2017 | 08:42 PM
garrettsf250
well I put new bulbs in and I think I may have fixed it can't really tell on the streets and it's rush hour traffic right now so maybe later I hit the highway and see how it does. Thanks agian!
Old May 25, 2017 | 06:19 PM
Shawn MacAnanny
Well thats much better than a new transmission, that wouldnt even have fixed the problem
Old May 25, 2017 | 10:08 PM
garrettsf250
indeed thanks for the tips 👌🏼
Old Jun 4, 2017 | 08:15 AM
flylooper's Avatar
flylooper
I've been monitoring this thread and ma having siminlar problems with my '03 SD and a flshing OD light. Wow! All that because of a light bulb! I'll check my rig in a few minutes.
I'm hoping (praying!) that's my problem too!
Old Jun 4, 2017 | 08:16 AM
Shawn MacAnanny
i think the 3rd brake light converter unlock is only in obs trucks
Old Jun 4, 2017 | 09:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It isn't your problem. That problem was corrected in the '99 and newer trucks.
The flashing OD light means codes have been stored that will direct the diagnosis. You MUST get those codes to get this fixed. The places that read codes free CANNOT read these codes. You need either a good independent shop or a Ford dealer.
Old Jun 4, 2017 | 10:06 AM
flylooper's Avatar
flylooper
DRAT
I will do that tomorrow for sure. Thanks for the comeback.I appreciate it.
Old Jun 13, 2017 | 02:58 PM
  #28
flylooper's Avatar
flylooper
Following up on previous post, I changed the tranny and torque converter oil...thoroughly...I flushed the assembly with gallons of good stuff and the tranny seems to be a happy camper. I drove the rig about 110 miles (mixed highway and surface streets) without any overdrive warning light flashing at me. The tranny works perfectly. Could this have done the trick? I will keep a close eye of course.
The old fluid was "tannish" colored so I decided to just put good stuff in there.
carney91
1997 - 2003 F150
Aug 6, 2017 05:13 PM
WinterRoad
Feb 27, 2007 05:41 PM
DantheMan99
Dec 13, 2003 08:25 AM
daimon1054
Jul 15, 2003 07:41 AM
