Heater assembly removal
Old May 22, 2017 | 01:08 PM
Darrellt's Avatar
Darrellt
Could someone kindly supply photos of the bolts that hold the heater assembly in place? Is it only the two I can see from the engine compartment? I can't see anything from inside the cab. This can't be that difficult. Thanks.
Old May 22, 2017 | 01:27 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I've always seen either 3 or 4 studs coming through the firewall into the engine compartment - depending on what year and model the truck is. Once those are removed the only other items are ducting, cable and wiring.
What year and model is your truck?
Chad
Old May 22, 2017 | 01:33 PM
Darrellt's Avatar
Darrellt
It's a 66 F250. I'd like to service it before finishing the interior restoration unless it's a major pain. It's working ok and not leaking etc.
Old May 22, 2017 | 01:44 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, same as my 2WD truck - in that case it should be 3 studs poking through the firewall in a triangular pattern. Like the picture in this post - this is the piece that is immediately behind the firewall.
https://www.ford-trucks.com/forums/1...l#post16921809
Chad
Old May 22, 2017 | 01:59 PM
Darrellt's Avatar
Darrellt
Okay that's what I was looking for. Two bolts must be hiding behind the wiper reservoir. One interesting note on the link you gave me. I haven't removed the tool box yet but will be interested to see if that rubber seal is there!
Thanks again.
Darrell
6978sghfbjklgdfsjhkl
Apr 9, 2013 06:12 PM
brians1979f100
Jan 3, 2010 08:53 AM
66f100352
Jan 11, 2005 09:09 PM
Arte
17
Oct 2, 2004 11:09 AM
Native Gearhead
Oct 27, 2003 11:48 AM
