Glow plug wiring harness
Old May 22, 2017 | 11:49 AM
tassmannn's Avatar
tassmannn
Does anyone know the part number for the glow plug harness in 1985 6.9, or an aftermarket harness? If I can find the clips, it looks easy to manufacture one. Just don't know where to find them either or what they are called.
Thanks in advance
Old May 22, 2017 | 11:51 AM
Franklin2's Avatar
Franklin2
They had two different styles of glowplugs. The early engines used a flat spade type connector, the later ones used a bullet type connector.
Old May 22, 2017 | 11:52 AM
Franklin2's Avatar
Franklin2
Here's the early style plugs with the early style controller.
Old May 22, 2017 | 11:53 AM
Franklin2's Avatar
Franklin2
Here is the later style with the later style controller.
Old May 22, 2017 | 11:57 AM
tassmannn's Avatar
tassmannn
It is the early style
Old May 22, 2017 | 02:32 PM
Franklin2's Avatar
Franklin2
Will standard ends like this slide over the glowplug connections?
Old May 22, 2017 | 04:24 PM
tassmannn's Avatar
tassmannn
I wish. They are wider than those. If I knew the name of the clip, I could probably find them
Old May 22, 2017 | 04:59 PM
tassmannn's Avatar
tassmannn
Well, actually I may need to measure the tabs. There is a site that has all kind of connectors. https://www.waytekwire.com/products/...k-Disconnects/
A good resource even if I can't find the one for the glow plugs.
Old May 23, 2017 | 07:59 PM
cadunkle's Avatar
cadunkle
I have a 7.3 bullet style harness and controller on ebay now. It needs new ends crimped on as the insulation has flaked off most of them. Just crimp new ends on and upgrade to the better 7.3 controller if you want to run a controller. Controller is untested off a parts engine. If you're interested let me know and I can end the auction, I'd let it go for whatever you think is fair. Just trying to clear out stuff I won't use.
Old May 23, 2017 | 10:00 PM
tassmannn's Avatar
tassmannn
Thanks., but everything is new on current system except the harness.
jwmoore89
Dec 16, 2016 07:14 AM
Forddiesel17
Mar 28, 2013 04:54 PM
Ardvarg
Dec 1, 2007 02:50 PM
leoniru
Mar 15, 2003 10:42 AM
