Front tank starting problems
Old May 21, 2017 | 10:15 PM
now_what's Avatar
now_what
Question Front tank starting problems
Hi guys, I have a 1996 Ford F250 7.5 V8 460 and I am having problems starting my truck on the front fuel tank. When I try to start it, it won't start even by pumping the gas peddle. But it starts right up when I have it switched on the back tank. I can start it on the back tank and then switch it over to the front tank and it runs great but it's just starting it when it's on the front tank. Any idea what it could be?
Thanks
Old May 28, 2017 | 12:54 AM
cbakker's Avatar
cbakker
Have you checked your fuel pressure on the front tank vs the rear?
Old May 28, 2017 | 03:24 AM
now_what's Avatar
now_what
Thank you for replying, I have not compared the pressure. Once the truck is stared and running I can switch to the front tank and have no problems driving, it's just starting it on the front tank that is the problem. Would not having good pressure effect just starting the truck using the front tank?
Thanks again for the help and reply!
Old Jun 12, 2017 | 08:36 PM
cbakker's Avatar
cbakker
Not 100%sure but if the fdm is weak, it may give enough fuel to keep it running but not be able to supply enough volume and pressure.
Old Jul 22, 2017 | 11:57 PM
now_what's Avatar
now_what
Update
Ok now the truck stalls when the tank is switched over. I was on the interstate and wanted to switch tanks and as soon as I did the truck lost power and I stepped on the gas and it started to stall like there was no gas getting to the engine so I switched it back and the truck regained power and ran like normal. Any thoughts?
Old Jul 25, 2017 | 08:30 AM
cbakker's Avatar
cbakker
I'm gonna guess it is the fuel sender(pump). The fuel sender is part of the fuel delivery module. Guessing is not as reliable as testing the fuel pressure and checking codes to make sure.
Old Aug 6, 2017 | 09:33 PM
now_what's Avatar
now_what
Smile Problem Solved
I replaced the fuel pressure regulator on the engine and it worked there is not a problem switching tanks now. Thanks everyone for the help.
Old Aug 6, 2017 | 09:40 PM
cbakker's Avatar
cbakker
Hope that takes care of it. Check back in later to let us know if it worked long term, or just to explore, as there is lots of good info here.
kgrice09
17
Oct 19, 2022 04:35 PM
mapu
13
Feb 5, 2013 04:11 PM
circa55
Dec 10, 2011 08:09 PM
MustangMatt96GT
Jan 26, 2009 11:08 PM
digr
Feb 7, 2005 08:01 PM
