c6 rebuild
Old May 21, 2017 | 04:42 PM
devils toy's Avatar
devils toy
c6 rebuild
I am hoping for some input here. I am rebuilding a c6 transmission and I had to get another case. The original fell off the jack and broke 3 ears off. Now I got another case and started to swap the parts and replace clutches, sprags, etc. I have discovered a few things different as I got deeper into the tranny. There is no boss for the detent spring and there is an extra port for the valve body where the vacuum module goes to. Am I screwed with the detent spring? It is column shift and the tranny bolted up to a 390. No ID tags on servo cover or on the pan.
Old May 21, 2017 | 08:43 PM
jk080's Avatar
jk080
Transmission Rebuilder
The case with out the linkage detent in the case and the extra port for the modulator is a 69 and earlier case , the other one is a late case.
You will need the valve body to match the case, so your late valve body will not work on a early case.
Name:  C6 69 valve body.JPG
Pipelinewelder20
Jan 5, 2015 10:20 AM
bshep
Aug 9, 2009 07:29 PM
gbroehl1
19
Dec 18, 2006 06:29 PM
kelsey
Sep 27, 2002 09:19 PM
