What Is This Part Called?
Old May 20, 2017 | 11:52 PM
HRTKD's Avatar
HRTKD
The end of my "gutters" on my trailer are supposed to end in a part that makes the water drip away from the side of the trailer. All four of these doohickies on my trailer are broken.
I don't know what to call them so I'm having a hard time searching for them. So what are they called? How easy/difficult are they to replace?
Old May 21, 2017 | 07:50 AM
Stroking along's Avatar
Stroking along
Rain gutters or gutter spouts. RV Gutter Spouts with Extensions, 4pk - Camco 42134 - Awning Accessories & Hardware - Camping World
Old May 21, 2017 | 08:00 AM
RV_Tech's Avatar
RV_Tech
There are a couple of different types if you are trying to match what you have.
Steve
Old May 21, 2017 | 08:39 AM
HRTKD's Avatar
HRTKD
The ones that Stroking along posted don't look quite right. But now that I know what they're called I think I can find a close match. Most of them are fairly inexpensive so if I order the wrong ones I'm only out $10.
All four of mine are broken off so I'm not sure how long mine were. I haven't got up there to do a close visual inspection so don't know how they are attached.
Old May 21, 2017 | 08:55 AM
RV_Tech's Avatar
RV_Tech
Two part versus all one part
Steve
Old May 21, 2017 | 09:16 AM
scraprat's Avatar
scraprat
Top Answer: 5
That style should work once you get the old off and clean the area. I used the same style on my last 5th wheel which was different from the origanl that was on it. Put some caulk around it and should be good to go. One thing if you haven't notice is that they might be different lengths of the spout. Plus there is is a style that is more rubbery than hard plastic which is the style in the pic.
Old May 21, 2017 | 10:48 AM
HRTKD's Avatar
HRTKD
I'm still trying to figure out how the prior owners managed to break all four spouts off.
Old May 21, 2017 | 11:07 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
They were prob never there.... most manufacturers don't use them. Usually a dealer installed part. Also if you DO put them on AND use a winter cover, come spring you prob won't have them anymore.
Old May 21, 2017 | 11:17 AM
HRTKD's Avatar
HRTKD
No, there are stubs left where they broke off. Otherwise I wouldn't have realized there was supposed to be something (that actually worked) there.
Old May 21, 2017 | 11:47 AM
RV_Tech's Avatar
RV_Tech
They often get brittle and break.
Old May 21, 2017 | 01:51 PM
BCooke's Avatar
BCooke
Broke 2 of mine hitting them with the brush while cleaning.
Old May 21, 2017 | 02:32 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Plastic don't last too long with the sun... the thinner it is the faster it breaks.
Old May 21, 2017 | 02:56 PM
scraprat's Avatar
scraprat
Top Answer: 5
That's why I like the ones that are more rubbery they are forgiving in colder weather and when cleaning. It seems like the plastics ones you just look at them and they break.
Old Jun 4, 2017 | 10:40 PM
HRTKD's Avatar
HRTKD
I've ordered gutter spouts from Camco and JR and neither of them are the right size. They're simply too big. The gutter part would stick out too far from the wall of the trailer. I can't find ones that are smaller. Are there any RV parts houses that are good at chasing down parts for you?
Old Jun 5, 2017 | 06:24 AM
JayTheCPA's Avatar
JayTheCPA
My RV was built without spouts and does not seem to effect anything by letting the gutters dribble down the shell. Once in a while I clean the streaks.
Roof leaks are definitely the bigger battle.
