tune-up specs
Old May 20, 2017 | 04:09 PM
56panelford's Avatar
56panelford
tune-up specs
Can someone tell me what the idle speed and timing should be for a 351(5.8) W with 2bbl carb. I can't seem to find anything in the way of factory spec's on the internet..
Old May 20, 2017 | 04:49 PM
Smitty49's Avatar
Smitty49
I'd start with 6º and work up to 10º using a vacuum gauge in conjunction with the timing light until you find the sweet spot.
Found this but's quite a write-up-
How to properly set the timing on a 302 or 351 - Ford Bronco Forum
Old May 20, 2017 | 05:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The problem with "factory specs" is that they would assume full emissions dress, which I seriously doubt you've got? I have a Haynes that covers it, but all it says is "see underhood sticker", because there were so many variations.
avellaneda13
Dec 7, 2015 11:09 AM
andrewasl
May 25, 2009 12:21 AM
66 custom cab man
Jun 16, 2005 10:01 PM
doyle beede
Oct 11, 2003 05:51 PM
waverunner
1978 - 1996 Big Bronco
Apr 29, 2002 09:49 PM
