1978 - 1996 Big Bronco
timing specs
Old Apr 24, 2002 | 09:52 PM
waverunner's Avatar
waverunner
timing specs
Does anybody know where I can find specs for ignition timing-87 Bronco 5.0 EFI Thanks
Old Apr 29, 2002 | 09:22 PM
thelonerangerxlt's Avatar
thelonerangerxlt
timing specs
The timing specs are listed on the Emissions sticker on the driver's side valve cover. If the sticker is missing, start with an initial timing of 10 degrees btdc. If it "pings", back it off to about 8 degrees. Good luck.
Old Apr 29, 2002 | 09:49 PM
Pilotrick's Avatar
Pilotrick
timing specs
