Hi all, need help with some wiring on 99 f350, it had a 7.3, 4r100 in it. I put a Cummins, 5speed in it. I pulled the wires for the neutral switch, and reverse lights out of the harness going to the auto trans. Everything works fine except now I don't have wipers, power windows, and the dome light flashes. any help is appreciated. AJ
What about all of the transmission control wiring, what happened to that? The powertrain module could be all screwed up since it's programmed for an automatic.
Hi Alloro, The trans control wires are there, but with the Cummins I don't need any modules, or computers to run and drive. I would like to eliminate all the unnecessary wiring and stuff, but don't know how that would effect the necessary things like charging, lights,ac,etc.
Thanks, I'm thinking I need something showing if any of the trans wires share a ground or hot with the wipers, dome light, and power windows. Also the abs light is on that wasn't on before the trans swap.
I understand the tranny doesn't need the computer, but the question is, does the computer need the tranny? Without the tranny is the computer (or GEM) acting up?
