Sponsored by: Real Truck
Trans wiring
Old Mar 25, 2016 | 10:14 AM
Powerstrokin_350's Avatar
Powerstrokin_350
Trans wiring
Got a question I hope someone can help clear up! 2005 F350 4x4 6L/auto truck. Can someone tell me what the transmission wiring/plugins do? There's the big one with the bolt through it and then 2 small plugs. Where in those would I locate the neutral safety switch wiring and the backup light wiring? Tia
Old Mar 25, 2016 | 10:40 AM
projectSHO89's Avatar
projectSHO89
It's not as simple as that.
Not at the transmission. On that truck, those functions are controlled by the PCM based on the output of the TR sensor which is inside of the transmission. The PCM then turns on relays in the CJB for the backup lights or enables the starter based on the data from that sensor plus whatever else it needs to satisfy its logic.
scotttahoe's Avatar
scotttahoe
I am no 5R110 expert, but are you trying to add back up lights that turn on in reverse. If so I would connect them at the trailer wiring harness as they run on their own fuse.
Sorry I can't help much.
Old Mar 25, 2016 | 12:30 PM
Powerstrokin_350
I had a feeling. It's actually a fummins and 6 speed. Looking to add these in. I hoped I didn't have to dig into the PCM wiring anymore than already have bit sounds like I have to!
bobappling
Jan 22, 2019 07:09 PM
ABurtt
Aug 11, 2016 04:17 PM
sleep_deprived129
Jun 7, 2007 11:36 PM
Andysutt
18
Mar 5, 2004 05:51 PM
