Sponsored by: Auxito
Towing question
Old May 20, 2017 | 02:25 PM
popsicleped's Avatar
popsicleped
Towing question
Hello. First time poster. I am looking at buying a camper but I have no idea how much I can tow. I tried looking online but just get more confused haha. Anyways, here is the information on the sticker inside the door:
GVWR 6950LB/3152KG
Front GAWR 1700KG/3750LB
Rear GAWR 1732KG/3800LB
With Tires:
P234/75R17
Rims: 17x7.5J
AXLE 26
Thanks!
Old May 20, 2017 | 09:48 PM
steve(ill)'s Avatar
steve(ill)
The truck has a maximum vehicle weight of 6950 pounds. That is NOT what it can pull. You need to give the year, model, motor of the truck to get the max trailer weight. For example, an average size truck might be 9000 pounds, minus 5500 for the truck weight would give a 3500 pound trailer.
Old May 21, 2017 | 12:52 AM
Bluegrass 7's Avatar
Bluegrass 7
Go into your owner manual to the section on towing and read the whole section.
In it you will see charts that list your equipage for motor size, transmission, rear gear ratio etc.
On the right side of the chart you will see a max Gross Combined Weight Rating (GCWR) for your truck's equipage.
Subtract your truck actual loaded normal weight from the gross combined number and that is the legal weight you may tow.
Do not use the door listing of Gross Vehicle Weight only your actual weight of the truck loaded as you would normally do.
That includes full tank of gas, passengers and any other items that add to the weight of the truck..
For example you may find a GCWR of 11,600 Lbs.
If you have your truck weighed and it goes 5600 lbs, it will be 11,600 minus 5600 will = the tow weight of 6000 lbs. max 'loaded' trailer weight.
Towing at the max or over will cause more wear on brakes, trans, tires etc. so expect it.
Also watch the 17 inch tire rating. It lowers the max weight you may tow as well as passenger P tire rating also is a reduction over an LT tire..
Just keep in mind you only have an F 150.
Good luck.
Old Jul 9, 2017 | 10:25 PM
Dgriff804's Avatar
Dgriff804
I would stick to under 6,000 just to be safe. My 99 f150 v.6l v8 supercab shortbed 3.73 axle ratio and 16" inch tires is only rated to tow 5,500 and I definitely feel it when I tow my 23 ft camper
Old Jul 9, 2017 | 11:24 PM
1999-F150's Avatar
1999-F150
My TT is 3500 lb dry. My trucks motor is on the weak side and it has a hard time pulling the TT, even on the flats. All I could get is 60-65mph. I ran 55-60 to be on the safe side. I think the motor is the limited factor not the suspension. I am running 3.73's and at this point I wish I had 4.11's because of the weak motor. My $.02 worth.
Thenewboss
All Things Towing
Dec 1, 2013 09:57 PM
sonar_91
All Things Towing
Nov 6, 2011 06:57 AM
Swanchek
1997 - 2003 F150
Oct 19, 2011 09:08 PM
NotMyHusbandsF150
2009 - 2014 F150
16
Aug 23, 2011 11:37 AM
docolena
All Things Towing
Jun 13, 2001 03:47 PM
