:( Broken Screw Extractor In Block :(
I snapped off 6 bolts in the block on my flathead (53 8BA) Trying to get the exhaust manifolds off. I successfully removed 5 of the broken bolts by welding a nut on the ends of the bolts and threaded them out. The sixth bolt was broken off flush with the block so I drilled it with a 3/16" bit and then tried to extract with a spiral screw extractor. The screw extractor broke off flush with the block. Bad idea, I should have just drilled and re tapped. So has anyone done this and has a remedy? Engine is in the truck so not much room to work in. Can another hole be drilled and tapped next to existing with matching hole drilled in header flange?
Hi,
can you apply heat right in the spot where the screw sits? If this doesn't work or you're not able to grab the remains of the screw or the extractor
you can try to bore it all out, starting with a small borer and working up
to a borer which is still smaller than the thread. This way you should be able to pry out the rest of the screw and extractor piece by piece. It's a pain in the a.. and you must be patient, but it should work.
Hopefully you can get it with heat and welding something to
it to turn it. On the critical equipment the "broke off flush"
stuff we always had to use a metal disintegrator on when
I was in the Navy. (you'd be pulling the engine to do that
level of nonsense....)
Electro Arc 2M-SA Metal Disintegrator w/ Magnetic Base for Portable Operation, T | eBay
I have never used a metal disintegrator or even heard of one 'till now haha, but I had the same issue with a water pump bolt on an old Ford Grenada. I drilled the remaining bolt that was broken off flush with a smaller diameter drill and proceeded to round of smoothly my whole collection of easy outs and to no avail. So what I ended up doing was redrilling the bolt out to the same size as original and retapping the hole. The bad part of that experience was I had to take the rad out to get room. I hope this helps.
Throw the easy out in the trash and buy a good set of left handed drill bits.
I **** you not you'll thank me later. I can't remember last time I use a Ez out. When I had my mill I would drill a hole in the bolt and swap out for a left hand drill bit. 90-95% of the time the drill would reverse the bolt out of the hole. If it didn't work I would drill through the bolt or mostly through it and then try again.
Just thinking out loud before suggesting taking to a machine shop or engine builder.
BUT
Could you put a big enough nut and weld it though the nut opening? Image placing the nut flush and lining up the bit through the threaded portion of the nut. Then taking your mig or tig and being able to weld it that way? Area maybe to small but worth a try if you have the means/ability to.
BUT
The water jacket isn't real thick except at the (factory) bolt holes.
If you have a MIG, just welding a big goober on the end of the EZ-Out should allow you to twist it out.
