2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
12V dash outlet not working.
Old May 20, 2017 | 07:39 AM
ssejnoha's Avatar
ssejnoha
My 12V dash outlet has not worked since I bought my 2013 F150 used last year. The Ford dealer opened the hood and looked at fuse 22 which was not blown. I took the outlet itself out of the dash and it looks like new never used but it tested ok like I thought. I tested the plug and found no voltage so now I know no power is getting to the plug/outlet. Does anybody know of any other fuses that would power this beside fuse 22 which is a 20amp fuse that the manual says powers it?
Old May 20, 2017 | 08:48 AM
alloro's Avatar
alloro
Fuses 22, 65, 66, & 72 all power 12v aux power outlets. Maybe they checked the wrong one.
Old May 21, 2017 | 04:56 AM
ssejnoha's Avatar
ssejnoha
I just looked and found the spot where 65 is supposed to have a fuse is empty. I am hoping buying a 20A fuse to put in that spot is the fix. The newer square fuses I have never seen what they look like blown. Is it very obvious like any other fuse?
Old May 21, 2017 | 09:30 AM
alloro's Avatar
alloro
Look in the spot for the #65 and make sure there are metal contacts in there for a fuse, you might not have ever had a #65 if your build options didn't call for it. If you do find contacts take the #66 fuse out and put in the #65 spot to see if the 12v outlet starts working. This way you can test it without having to buy anything.
fordranger94
1983 - 2012 Ranger & B-Series
May 21, 2018 09:59 AM
Sully66
Apr 18, 2018 07:00 PM
quietman
Mar 21, 2013 09:06 PM
mmmPowerStroke
Nov 23, 2004 11:51 AM
dan831wv
Sep 24, 2003 02:11 PM
