98 e250 5.4 engine compatibility
Old May 18, 2017 | 12:04 AM
TAMatheny's Avatar
TAMatheny
Ok, so we recently bought a 1998 E250 van with the 5.4 triton. It has a spun bearing, and we decided to put another engine in it instead of rebuilding. So my question is, what years and models are compatible? I have near about exhausted Google trying to find out. Does anybody know?
Old May 18, 2017 | 12:30 AM
Sam I Am's Avatar
Sam I Am
97, 98, 99 year model
5.4L long block from a van or truck are a direct replacement.
If you get a truck long block some things will need to be changed like the oil pan & pick up tube, trans dipstick tube, external stuff like that.
Old May 18, 2017 | 04:43 AM
Wildman25's Avatar
Wildman25
Simple cross check for fitment is to go to Rockauto.com, select year, model, engine, select part *engine*, click on "blue" part number and a pop up window will appear on fitment.
An F series should also fit, only real difference is the oil pan, vans have a rear slump, same as a 4 wheel drive F series. If you come a cross a junk pick-up, you'll need to remove all the accessories anyways to remove the engine from the van, and just reinstall the van accessories.
mcolabella
Sep 15, 2014 02:15 PM
wade8422
1997 - 2003 F150
Nov 27, 2012 07:30 PM
fordyduty
Feb 25, 2010 06:05 PM
rickatic
Feb 8, 2010 08:27 AM
okcf150
1997 - 2003 F150
Dec 10, 2009 05:38 AM
