1978 - 1996 Big Bronco
Need some help
Old May 17, 2017 | 08:29 PM
oravecz1's Avatar
oravecz1
Need some help
Howdy y'all! need some help with my 84 bronco xlt full size, I put a whole new starting system(starter, solenoid, cables, ignition switch) and now when I try to start my bronco the starter stays engaged when the engine is running and the key doesn't spring back, anybody have any ideas as to what this may be caused by? Any help is much appreciated.
Old May 18, 2017 | 07:49 AM
Redark1's Avatar
Redark1
not sure how the lock cylinder is connected to the ign switch but i would think there is a spring that helps it return to its run position. if the only spring is in the switch then you might have put it in a bind and its not returning on it's own.
Old May 18, 2017 | 02:37 PM
AlM's Avatar
AlM
The ignition switch, mounted inside column's shroud is where the spring-back is provided, but actuator(s) is often damaged.. Ensure switch is securely mounted first.
Ignition Actuator Replacement on an '85 w/tilt by Chris B @
Ignition Actuator Replacement on an '85 w/tilt - Ford Bronco Forum
Here is a good rebuilder 1980-1991 Ford Rebuilt Steering Columns | Steering Column Services
Old May 18, 2017 | 03:15 PM
AlM's Avatar
AlM
The actuator transfers the rotation of the cylinder to the push/pull of the rod. The rod is on top of the steering column so the actuator needs to transfer that motion around the steering column from the key cylinder to the rod.
Ignition Lock Cylinder Adjustment & Switch Pin-Out Diagram & Continuity Testing (Logic Tables) in an 83; "...The following proceedure is from the 1983 Ford Service manual, with a few minor wording changes, but should work for any year. Also included are a couple of illustrations from the same proceedure to help you visualize it..."
Source: by Seabronc (Rosie, Fred W) at Ignition Switch Adjustment Proceedure - How-To Tech Articles & Reviews - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Old May 19, 2017 | 03:14 PM
oravecz1's Avatar
oravecz1
awesome thanks for the help! ill pull it all apart tonight and see where it goes!
Old May 20, 2017 | 09:35 PM
oravecz1's Avatar
oravecz1
UPDATE!
Thanks again for the help y'all! So tore down the steering column and found the ignition actuator was broken
softshoes
1983 - 2012 Ranger & B-Series
19
Oct 2, 2021 09:13 PM
jhruzek
Jul 13, 2015 11:55 PM
jdusten81
Apr 11, 2011 08:08 PM
PauL3861
May 13, 2009 10:33 AM
uscrpick
Jan 21, 2005 05:34 PM
