Colder A/C ???????
Old Sep 3, 2003 | 11:57 AM
williamwilliam's Avatar
williamwilliam
Colder A/C ???????
Hey got, finally got a factory A/C unit installed in my 1972 Ranger XLT that I am getting ready to restore. It works pretty good, but it is not as cold as I would like it to be. Any suggestions as to what I could do to get it colder? I have a new condenser and dryer on it. All foam on the insdie of the unit is new. I had 2 units and one of the exspansion valves didnt work so I used the one off the other unit. Could it be that this valve could be my problem?? Any suggestions?
Old Sep 3, 2003 | 11:27 PM
Colossus's Avatar
Colossus
Colder A/C ???????
My dad's 78 F250 has a/c, and it isn't that cold either. If you want colder, I would look to an aftermarket a/c.
Old Sep 4, 2003 | 08:35 AM
HomerWinzlow's Avatar
HomerWinzlow
Colder A/C ???????
I would try a NEW expansion valve and ensure there is no garbage floating around the system. I trust you made sure the evaporator wasnt clogged up with dirt, doghair, and crusty stuff which would reduce performance. If it has a recirc door you may want to ensure it is working. Are you using R12 with this system? R134 would probably not perform well with an expansion valve setup.
Old Dec 6, 2003 | 02:16 PM
Nomadd22's Avatar
Nomadd22
The biggest problem with ac installs not blowing as cold as they should is installers not vacuuming the system right. It only takes a tiny bit of air in the mix to greatly reduce the cooling efficiency.
American Air-1
Oct 31, 2012 03:03 PM
1974f250
37
Jun 17, 2010 10:14 AM
Bombero
2004 - 2008 F150
52
Jul 16, 2007 07:52 AM
Bad78
Jun 11, 2005 09:50 AM
