Sponsored by: Auxito
Clunks / snapping noise
Old May 17, 2017 | 11:30 AM
whoznextlive's Avatar
whoznextlive
I have read through many threads and still have not found one that is simalir to my issue.
vehicle: 01 F150 5.4 4wd
issue: snapping sound like crushing tin can at take off and now at a fast stop.
Repairs already done:
upper control arms
lower ball joints
Sway bar link and bushing
4wd cv axle shaft assembly (both side )
Slip yoke grease.
Tie rod ends replace inner and outer
I put the truck an a lift and put it on drive and there is no sound.
Old May 18, 2017 | 06:53 AM
Bluegrass 7's Avatar
Bluegrass 7
Have you checked the U joints on the drive shaft?
When the needle bearings begin to breakup and fall out, you get noises and snapping.
The driveshaft can make it sound a bit unusual at times under acceleration the way a hollow shaft can transmit sounds.
Good luck.
Old May 19, 2017 | 10:09 PM
thzpcs's Avatar
thzpcs
^ This sounds right
JoeDirt68
Dec 31, 2010 06:44 AM
rusty350250
1997 - 2003 F150
Jun 23, 2010 10:56 AM
cabloom300
Sep 10, 2009 04:49 AM
Beast12
1997 - 2003 F150
25
Nov 9, 2008 03:51 PM
brownbronco
1978 - 1996 Big Bronco
Dec 11, 2007 09:23 AM
