Weather stripping help
Old May 16, 2017 | 11:51 PM
LeviD's Avatar
LeviD
So I need to replace my door window weatherstripping and my door weather stripping. Seems like most sites have additional things and I'm not real sure what I need for just those items. Would it be possible for someone to line me out on what stripping I need since I don't know the specific names for the pieces I'm not sure what it all is.
Old May 17, 2017 | 06:48 AM
CelticOne's Avatar
CelticOne
Regular User
Check out Jeff's Bronco Graveyard. Their quality is better than most (LMC!). This kit should have all you need (and lists original part numbers):
73-79 Ford Bronco, Truck & Crew Cab Door Weatherstipping Kit-Broncograveyard.com
Old May 17, 2017 | 02:03 PM
LeviD's Avatar
LeviD
That kit should do it for all the window as well? The installation video only shows them installing the cab stripping. Seems silly to have a video attached that doesn't show any door lol.
Old May 17, 2017 | 02:34 PM
CelticOne's Avatar
CelticOne
Regular User
Yes - it includes door and window pieces for both doors.
Old May 17, 2017 | 02:41 PM
LeviD's Avatar
LeviD
Thank you very much for linking that by the way.
Old May 17, 2017 | 09:24 PM
maytea's Avatar
maytea
Re
I do not see details on type of door weatherstripping fro JBG
I picked up the door weatherstripping from them last summer.
It does not have the metal core
You need adhesive to get it to stay on
I don't plan to install the adhesive type and have been looking at posts that used the snap on steel core from a latter model truck
Old May 17, 2017 | 10:13 PM
LeviD's Avatar
LeviD
The 2 window pieces that go on the door aren't the snap on kind? The rest I know shouldn't have metal but I was wanting that style for the window for sure.
Old May 18, 2017 | 12:34 PM
maytea's Avatar
maytea
Re
no steel core for the window pieces
What I mean is the metal core for the door frame rubber is available and can be substituted so you do not need to use glue
Old May 18, 2017 | 02:30 PM
Tracktor's Avatar
Tracktor
Use the mid-90s truck weatherstripping for the doors. Pops right in.....
Old May 18, 2017 | 08:55 PM
lafermedavid's Avatar
lafermedavid
ck out precision weather stripping videos ,they are helpfull,,,,I just put there door jamb weather seal the cinch on type,1981 and up,good quality,.I also picked up the rear window seal ,good stout quality,,,I will be going with DC for the front window ,I have the early seventy's wide ss
dbeast1113
13
Mar 11, 2018 04:18 PM
FossenRacing
Feb 10, 2013 10:14 PM
rmallow77
Oct 14, 2008 02:42 PM
Gobstopper
Apr 10, 2002 05:59 PM
