Fuel reset switch
Old Sep 3, 2003 | 11:01 AM
duckpinjoe's Avatar
duckpinjoe
Fuel reset switch
I have a 1997 Ford f-150 that was involved in a small accident.The damage was to the front end.It is not bad but when i try to restar it will not.Somebody told me that it is the fuel reset switch.Can someone tell me where it is located
Old Sep 3, 2003 | 11:10 AM
jbalestri's Avatar
jbalestri
Fuel reset switch
What you are looking for is called the "Inertia Switch". Sometimes they are on the passenger kickwall area, behind the brake/clutch assembly on the firewall, and sometimes even in the engine compartment. It should be alittle black box about 2"x3" and have a plug with two wires going into it and a red or white button on the top. Either press the button down, or pry it up with a screwdriver.
Let me ask you this, when you first turn the key to "on", do you hear the fuel pumps running? It should be an electrical whine for 10 seconds or so, and then it quits. If you do, the problem is not the inertia switch.
Welcome and hope this helps some. Let us know if you need more info.
Glenn Blackwell
Aug 6, 2014 05:15 AM
robl74
Dec 17, 2010 10:10 AM
scaryracer33
Aerostar
Jul 23, 2006 10:08 PM
94/150MN
Oct 26, 2004 09:23 AM
jay_s5
Dec 5, 2001 12:32 PM
