Fan issue
Old May 16, 2017 | 05:34 PM
VictorwithaC's Avatar
VictorwithaC
Originally Posted by jsm180
Heli-coil is an easy fix for your housing if you have the tools and know how. If your deltas go up with ECT you need to fix that first. Before I pulled the oil cooler I would back flush it and run 3 qts of restore through it. If your deltas stay below 15* leave it alone and just change the thermostat.
no my deltas are bad regardless of ect. 65 unloaded tuned or not their about 16* 192-194 ext 206-210 eot. Before headgasket they were max 6* hell I'm at 8-10* usually cruising town. Gonna try that little guy first as i dont see how i ruined my cooler it was new and I didn't flush before gaskets.
Old May 16, 2017 | 05:45 PM
jsm180's Avatar
jsm180
Back flush and restore. I clogged mine just changing coolant brands, went from Cat ELC to Zerex ELC and gelled it. Easy fix with Restore. Your coolant to water mix will raise deltas too.
Old May 16, 2017 | 06:00 PM
ericwudi0830's Avatar
ericwudi0830
i think you'll be ok
Old May 16, 2017 | 06:11 PM
VictorwithaC
maybe I'll give it a shot then. I did put new coolant in it because I had oil contamination. I flushed with cascade for an hour then 20 gallons of distilled water was Crystal clear when it came out. New elc at a perfect 50/50 mix. Could still be clogged which I hope isn't true but I just find it unlikely.
Old May 16, 2017 | 06:17 PM
VictorwithaC
if your talking about my deltas ya I agree honestly wasn't gonna do anything about it for a minute. Was more concerned about my coolat.
Old May 16, 2017 | 06:38 PM
Yahiko's Avatar
Yahiko
If you use the flush chemicals you can plan on a oil cooler down the road.
Old May 16, 2017 | 06:43 PM
VictorwithaC
yea I don't think I'm gonna. Looking at 15* yea it's not ideal but no egr cooler I think it will live for a bit longer. Plus I just did a bunch of work on it and the wife will kill me if I tear her open again.
Old May 16, 2017 | 07:10 PM
Yahiko's Avatar
Yahiko
When you do get around to doing be sure to take the radiator out
and turn upside down and flush out anything that has been hiding
in the top tank. A lot of crap can collect there.
Old May 16, 2017 | 07:45 PM
VictorwithaC
yea for sure. I think I'll do the thermostat again and see what that changes. Hopefully will be able to get the bolts back in though
Old May 16, 2017 | 11:03 PM
Yahiko's Avatar
Yahiko
Spray it down with some Kroil.
Old May 17, 2017 | 06:58 AM
VictorwithaC
you think that will help with it being cross threaded?
Old May 17, 2017 | 07:40 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The t-stat housing bolt holes in the front cover aren't blind. Pull the bolt, clean up the treads and see if it was really cross threaded. If it was, step it up a size and tap it. Are you sure it was cross threaded, or does it just need to be chased?
Old May 17, 2017 | 08:21 AM
  #28
VictorwithaC
I'm pretty sure as I've taken it out several times and cleaned it but maybe I should blow out the hole.
Old May 17, 2017 | 12:30 PM
  #29
mtfuji's Avatar
mtfuji
I was having low fan speeds (300-400 rpm) in town, so I changed out the fan clutch for a snow plow one. Now I see from ( 500-700 rpm) and up to 1100 on the highway, cools much better and I can't hear the difference.
Old May 17, 2017 | 01:14 PM
  #30
Yahiko's Avatar
Yahiko
Sadly that won't help that
