1978 - 1996 Big Bronco
Idle high
Old May 15, 2017 | 02:37 PM
Iron Port's Avatar
Iron Port
Idle high
My 1993 Bronco 351w e4od is idleing way too high, around 2000 rpm. It would take a while for it to idle back down to 1100 rpm, and thats high too. It would shift extreamly hard into reverse it would shake the entire truck and it would clunk into any gear. It gets up to 10 mph at idle. Does anyone have a fix?
Old May 16, 2017 | 05:51 AM
gatorfor88's Avatar
gatorfor88
pull the codes
Old May 23, 2017 | 08:28 PM
greystreak92's Avatar
greystreak92
Originally Posted by gatorfor88
pull the codes
and check for vacuum leaks. (Codes could be indicative of vacuum leaks depending upon what comes back from the KOEO/KOER tests.
Old May 28, 2017 | 11:04 AM
Encho's Avatar
Encho
The Southernmost Mod
Also, if you decide to, do some maintenance: Get a throttle body cleaner can (no carburetor cleaner) and clean the throttle body and the mech part of the IAC valve. use nothing else but the can, no brushes or anything, and follow the instructions on the can.
Black Ford XLT
20
Jun 8, 2011 05:44 AM
smertlich
Feb 10, 2011 08:17 AM
00GT
1983 - 2012 Ranger & B-Series
Jun 13, 2007 09:11 AM
1987F-150
Jun 23, 2005 06:07 PM
peppy
May 8, 2004 08:46 PM
