compast & outside temp.rear view mirror
Hi everyone, I have a 1998 E150 starcraft conversion van, with the compast & outside temp. indicator mounted on the rear view Mirror. I don't know why... this spring, after winter storage, it all decided to work ! (last year, it never worked) But I am not sure if it is normal to have ''constant current'' on it. I mean, if I don't shut down the switch on top of Mirror, it will display all the time... is it normal ? Also, what would ''DO'' stand for on the screen ? I see the compast display (''N'' for north) but no temperature display !
So far this van had weird electric issues. Does anyone ever heard about water leakage in the inside fuse boxe area, causing water to short circuit some accessories ???? Speaking of leakage, any well known areas to look for, for the water to gets Inside the van in the parking brake & brake pedal area ?
thanks for any tips !
nickmobile67
03-26-2004 06:48 AM
Bikerider900
10-02-2003 09:13 PM
