Trans problem on first drive
Old May 14, 2017 | 07:47 AM
reg1952's Avatar
reg1952
Finally get my truck back together after 2 years of not driving it. It was all apart for final paint and a rebuild AOD (So I was Told when I bought it). First drive the trans would shift into overdrive and then the engine would just rev. Great!
Took trans back out and opened it up. Everything is new put as you can see the OD band it smoked. I bet who ever had this trans last never adjusted the TV cable right.
I have another trans so I opened it up to get the rev drum and its a little different . I think its an updated drum. Anyone no for sure?
Old May 14, 2017 | 10:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you know what year the AOD is? Around the late 80's they were making the OD servos heavier duty for cabs, police, Mustangs, etc. By the early 90's they were a lot stronger. But you are correct, the TV cable was the weak link, only takes a few miles with it wrong to fry them.
Old May 14, 2017 | 12:23 PM
reg1952's Avatar
reg1952
It was out of an 90 Crown Vic. Been doing some reading and there is a servo update. My servo has a B on it. The stronger one says an A.
Old May 14, 2017 | 01:44 PM
EBEAR's Avatar
EBEAR
I believe the 90 should have most of the better parts ,there are numerous parts from an aode that are better yet and can be swapped in .
Old May 14, 2017 | 07:42 PM
ben73058's Avatar
ben73058
Hi Reg,
Sorry to hear about your AOD problems.. I would recommend Baumann
Engineering. They have a great site with everything you would ever want to know on AOD & AODE transmissions.
We upgraded our 351W & needed to beef up our AOD to handle the HP.
Baumann Electronic Controls Company History
We went with a Kevlar Overdrive Band from Baumann as it's common for the stock one to slip off under acceleration.
We also used their upgraded Overdrive Servo. They come in (3) flavors - you want to use the strongest 2 inch Servo.
The Base AOD comes with a weak 1.5 in. servo.
Setting the TV Cable is very hard to get right ...and very small adjustments can give you large pressure changes.
Don't feel alone - We broke (2) AOD's before finding an old guy AOD expert at a Trans shop.
Good luck over there.
Ben in Austin
1950 F1 (351W/AOD)
Old May 15, 2017 | 01:19 PM
petemcl's Avatar
petemcl
Originally Posted by ben73058
Setting the TV Cable is very hard to get right ...and very small adjustments can give you large pressure changes. Don't feel alone - We broke (2) AOD's before finding an old guy AOD expert at a Trans shop.
That is why I went with a 4R70W. There is no TV cable. Shifts can be adjusted through the Baumann Controller.
Pardon the mess. Still working on the wiring to other parts of the vehicle.
Old May 15, 2017 | 02:26 PM
raytasch's Avatar
raytasch
Believe Nothing
And one reason I went with the 700R4. Simple TV adjustment and bulletproof.
4x4-jacked-up-93
Jan 14, 2011 12:19 PM
Hitokori
Dec 4, 2009 05:53 PM
bfbiker
Dec 8, 2008 11:39 AM
neon4x
Aug 26, 2007 11:15 AM
mauicruza
Jan 22, 2006 08:24 AM
