Sponsored by: Real Truck
$60 AE scan tool EOBDIV EOBDV OBD2
Old May 13, 2017 | 06:26 PM
IFLFORD's Avatar
IFLFORD
Found this on ebay ,,, wondering if it is the right tool for '01 7.3?
I am trying to pass emissions in CO. I pass everything except that the SES light comes on when you get into the throttle too long. Happens at about 45-50 MPH only at WOT.
I am trying to find an affordable option to pull the stored codes.
It had some sort of chip on it that was attached to the sensor wires that were going to a sensor that is housed in the 'snorkel' thingy for the air filter.
It was throwing the SES with that "MB performance" chip thing on it. SO I removed it but the wirres are just dangling there. Anyone know what that sensor is? It is located in the hose leading to air filter.
Will this Autoenginuity scan tool work?
AutoEnginuity Windows EOBDIV EOBDV OBD2 Scan Tool Scanner (USB) | eBay
Thanks
Old May 13, 2017 | 09:08 PM
projectSHO89's Avatar
projectSHO89
Sounds like a typical ebay ripoff. A cheap resistor placed in the signal line for the intake air sensor and sold as some magic chip that increases fuel mileage AND power. Yeah, right!
Anyway, remove it and reconnect the original wires to each other. Reset the PCM's memory, then drive it normally and see if it will pass emissions test. You can worry about scanning it later if it's actually needed.
94stroker
Mar 21, 2011 05:00 PM
lloydmiiller
Computer Chips & Tuners
Jun 16, 2009 05:49 PM
Flash8
Sep 11, 2008 10:09 AM
will-ford
2004 - 2008 F150
May 4, 2008 01:45 AM
Moyerboy
1997 - 2003 F150
Mar 7, 2007 08:45 AM
