Trouble shooting Duraspark ll system on the 65, possible ignition coil, best as I can determine ohm reading on primary winding a bit low? Understand there's a 'coil' specifically for the Duraspark Ignition? Cyber searching and came across this deal; O' My, but then noticed seller does offer 'Free Shipping'.
The module is blue, appears the E8AF-12029-BA, nor the B6A-12029-B is correct for the Duraspark ll application? Unfortunately, coil currently installed does not offer a manufacturer's I.D., or PN, other than writing with a # 708 stamped on the bottom? Hoping to find the correct coil but appears may have to start searching for an aftermarket replace'mt? Intend using the same coil 'pick up' harness that snaps on the coil.
Appears the E8TF-12029-BA .. B6A-12029-B is incorrect for the Duraspark ll application!
The numbers the seller listed are E8TF-12029-BA ~ BGA12029B ~ DG5
BGA12029B is an invalid part number, it's actually B6A-12029-B
E8TF-12029-BA is an ID engineering number, it crosses to this same Ford part number: B6A-12029-B (Motorcraft DG-5)
This is the WRONG coil for DuraSpark. --------------------------------------------
This is correct: D5AZ-12029-A .. Coil (Motorcraft DG-314).
