Introduction/First Post
Old May 12, 2017 | 03:40 PM
jpmess's Avatar
jpmess
Hi All,
Wanted to post an introduction as I've been lurking for about a month, trying to get details on upgrades, mileage, parts etc. I recently was gifted my grandfathers 1977 F250 2wd Custom Camper Special in copper metallic with a 460 and 3 speed C6. He bought it off the lot here in the bay area. I'm not sure which GVWR version it is but will get details on that when its parked in my driveway! I believe 145k is on the odometer, dual tanks, everything is factory (a motor rebuild at 88k unsure why), and hauled a 12 foot slide in camper all over North America. The camper has been out of the truck for about 10 years and has been just a sunday driver since the camper came out.
It has a few hiccups at the moment, which I'm sorting out slowly. Backfires, won't shift into third unless manually put through gears on the column, what I think is a rear main seal leak. I have the original 5 volume 1977 Truck shop manual. It's been on my father in laws driveway for about a year and started monthly, so I'll be going through the carb, draining fuel, fresh oil/filter, etc. My son is three and its really going to be his someday, but I'll be taking care of it until then.
I do have a question on smog as I'm in CA. It passed smog two years ago, and I'm assuming it will pass smog this year once I have it running right. I want to make sure I'm armed with the right info when I go into the smog shop. I'd like to put a different carburetor and cam into it at some point but will cross that smog bridge when I get there. Because of the GVWR and dual tank it's basically the sniffer test and visual to pass? My grandfather only lives about 5 miles from me, so I'm hoping to use the same smog shop as he has throughout the trucks life. I'm in San Jose, ca if anyone has any suggestions
Old May 12, 2017 | 10:35 PM
dads1977's Avatar
dads1977
Welcome to FTE
Congrats on inheriting a family heirloom.
and your plans to keep it that way,
a couple of quick pointers
be sure to read the "stickies" in red
lots of crucial info on our trucks,
second be sure to join the NorCal chapter you will find a few members who are close to you up there.
third, post pictures of your "new to you" truck, We here like pictures
(yeah we are that kinda sick )
so don't be afraid to ask any kind of questions on what ever kind of hiccups you experience.
as to you transmission troubles i would recommend checking the fluid level, then if need be have it serviced could be as simple as a dirty filter inside,also check the vacuum hoses
If your in doubt about it passing smog here in commiefornia, go and talk with the smog tech at the shop where the truck is known and get some pointers and see if they will run you off a diagram for your truck, it worked for me
p.s.
metallic copper
Old May 13, 2017 | 12:05 AM
PapaBearYuma's Avatar
PapaBearYuma
Welcome to FTE-lots of good people jere, and often willing to help
Congratulations on your acquisition! I rather enjoy mine, also...
Old Jul 16, 2017 | 04:41 PM
jpmess's Avatar
jpmess
Finally got a few pictures to post of the truck!
Everything is very clean, body has a few dents and dings but it was used as a truck and will stay that way! I charged the batteries last night and it turns the starter just fine. Both tanks are empty so I'm going to drain them run some gas through them to be safe. I can see a few vacuum hoses that look like the ports have deteriorated and need to be replaced. All in all, it won't take much to get her running again shortly.
It it looks like it has 117k on the bodyroughly 50k on the rebuild.
Old Jul 16, 2017 | 04:44 PM
PapaBearYuma
Very nice!
By the way, that passenger side mirror will be more effective if you turn it over...
Old Jul 16, 2017 | 07:33 PM
CelticOne's Avatar
CelticOne
Regular User
Man there is a lot of stuff under that hood! I really like that old Alpine deck.
Old Jul 18, 2017 | 05:23 PM
jpmess's Avatar
jpmess
Originally Posted by PapaBearYuma
Very nice!
Ha! I think you are right!
Old Jul 18, 2017 | 05:25 PM
jpmess's Avatar
jpmess
Yeah everything seems to have been shoe horned into that engine bay!
Old Jul 19, 2017 | 03:23 PM
jpmess's Avatar
jpmess
Interesting, I started looking at the paperwork that came with the truck. I found the, maintenance log, original DMV docs, dealer docs, and receipts for payment from 1977. If I remember correctly, the receipt says he paid around 7k from Mountain View Ford here in the bay area.
Though it doesn't look dark enough, the color option on the dealer docs say the color is dark cinnamon glow.
I also found this under the seat and explains the horn speaker in the engine bay.
Big-Foot
All Things Towing
50
Jul 14, 2017 08:32 PM
ChristiansenP
13
Jan 25, 2016 09:02 AM
theodore/teddy
May 23, 2015 07:05 AM
kilich
Jul 13, 2011 10:56 AM
Durockrolly
Jan 1, 2009 07:06 PM
