truck leaning
Old May 12, 2017 | 02:11 PM
rocket_scientist's Avatar
rocket_scientist
truck leaning
2017 F-350 CCLB leans about 3/4" lower on the driver side than the passenger side. I thought my gatorbacks were installed wrong and today the mechanic put it on the alignment rack and we measured several points on the truck (ground to center of wheel wells, top of frame, bottom of mudflaps, top of bedrail) and it's off.
Anyone else notice this? Ford is going to look at it Monday but I suspect they will tell me to live with it.
This lean is without me in it and about 38 gallons of fuel left in the tank.
Old May 12, 2017 | 04:20 PM
yamaguy's Avatar
yamaguy
I measured mine the other day and it is the same way. My 2014 was the same as well, and I took it to ford and they said that it has to be an inch or more and in the first 12 months of ownership. I think part of the problem is the springs are so soft in the first few inches of travel to make the ride better that even a full tank of fuel can make the list to the side...
Old May 12, 2017 | 04:23 PM
K A M's Avatar
K A M
Did you have a spray in bed liner installed where they pulled the bed bolts. If so they put them back on with an impact until it could not go anymore. It's happening to several that do this.
Old May 12, 2017 | 08:49 PM
rocket_scientist
Well it obviously leans to one side when I put my 300 lb foot on the running board, but empty I would expect it to be level.
I have the factory spray-in bedliner. I think they do that right over the bed bolts.
Old May 12, 2017 | 08:52 PM
Tricon's Avatar
Tricon
Tried measuring with an empty tank?
Old May 12, 2017 | 09:10 PM
rocket_scientist
Is the tank on the driver side? I always just assumed it spanned across. I have not tried measuring with an empty tank, however I have always wondered if it's a little crooked whether or not the tank is full or empty. Thanks for the suggestion.
Old May 12, 2017 | 09:13 PM
Tricon's Avatar
Tricon
My Tundra did the same thing with a full tank. It favors the driver side for sure.
Old May 12, 2017 | 09:21 PM
skanj0's Avatar
skanj0
Super Duty's all lean to the left. Been this way since the early 2000s. The weight balance is off right to left.
PMF sells 1/4" coil spring spacers for this very reason. Ford has had a TSB for the issue since the mid 2000s but unless it's off by over 1" side to side you won't get a new leaf spring. If less than 1" they will install a spacer ship. They won't touch the front end at all.
Old May 12, 2017 | 09:23 PM
skanj0's Avatar
skanj0
Yes, the fuel tank, DEF tank, steering box and column, transfer case output, and of course the driver, are all on the left side.
Old May 12, 2017 | 09:53 PM
rocket_scientist
Thanks for the info. Do you happen to know the TSB number?
Old May 12, 2017 | 09:58 PM
wb6anp's Avatar
wb6anp
The Superduty isn't the only one that leans, look at just about any motorhome that is on the Ford F-53 chassis, they all lean to the right, and in this case its not the fuel, as their fuel is in the back between the frame rails and centered. Ours leaned so much we had to put in a 2" spacer on the leaf springs.
Old May 12, 2017 | 10:09 PM
user 474747383's Avatar
user 474747383
Last one I had that leaned I just reached the left rear spring 1" and done. Any spring shop.
Old May 12, 2017 | 11:20 PM
skanj0's Avatar
skanj0
This is the first version of TSB that I located. It's for the 6.0l super duty's but it is still in effect.
File Type: pdf
Old May 16, 2017 | 08:59 AM
rocket_scientist
The dealer measured the truck and found it off. I then went and put 20 more gallons of fuel in it and came back and it was more off. So it seems that it relates to the amount of fuel in the vehicle. Obviously when I get in it after that, it will lean even more. The dealer says (as I've read online before) that the progressive springs cause that problem. I'll just have my mechanic put a 1/2" shim in it on the driver side and be done with it.
They did contact Ford and will let me know when they get a response.
Thanks to all for the advice.
Old May 16, 2017 | 12:21 PM
skanj0's Avatar
skanj0
I measured my 2016 over the weekend after detailing it. The drivers side (left side) is 1/2" lower than the right - front and rear. This is with 2/3 of a tank of fuel (Titan 50g tank), and with heavy duty coils in front and an add-a-leaf in the rear. Cab and bed were empty too.
