Part question
Old May 12, 2017 | 07:30 AM
Watcher58's Avatar
Watcher58
Part question
What do you call the valve cores that are in the low and high side pressure ports on the AC. Sniffer went crazy over the high side port. I took off the cap and it went off. I left it off a few minutes, it still picked up a little. I put my finger over the port about 10 seconds and then tested it and it went off big time. There was a little bit of a reading on the low pressure side...very very small but there. Anyway, I definitely need to replace those valves--I think they are Schrader valves but I'm not sure. I know finding a Ford part # will be a blast
Old May 12, 2017 | 11:38 AM
smokekiki's Avatar
smokekiki
They are Schrader valves. The system needs to be evacuated to change them.
Old May 12, 2017 | 12:06 PM
smokekiki's Avatar
smokekiki
I just talked to a co-worker that worked at a dealership, he said they make a tool to change the valve, without losing hardly any of the charge. You can take it to a shop, or buy the tool.
Mastercool (MSC81490)
R-134a Valve Core Remover/Installer
Old May 12, 2017 | 12:48 PM
lightflyer's Avatar
lightflyer
Here is the video:
Pretty darn cool!
Old May 12, 2017 | 03:42 PM
Matt M, PA's Avatar
Matt M, PA
I have that A/C schrader tool set...very helpful...
Old May 12, 2017 | 11:45 PM
Watcher58's Avatar
Watcher58
Thanks-this all helps a lot. If you have had the original charge in the system,in my case, 13 years, would it be wise to go ahead and evacuate the system? I have a pump for it. Also should I replace the orifice tube and expansion valve, I understand they get crud in them... as long as it doesn't get overly complicated.
Old May 13, 2017 | 06:46 AM
projectSHO89's Avatar
projectSHO89
Try tightening the core first before assuming it needs replacement. I've seen ones that were loose and all it took was a bit of snugging up to correct the leak. Also, be sure to use the exterior caps and that they can seal properly. The caps not only keep the service ports clean, they can help to slow down any leakage by acting as a secondary seal.
The tip about the MasterCool tool is a good one, it isn't mandatory any longer to evacuate the system to replace the valve cores. However, starting from a completely empty system that's been vacuumed does allow for an accurate charge provided proper procedures are followed.
jlillie
Mar 17, 2016 05:08 PM
Jonnys.1991
Aug 25, 2015 10:27 AM
TheACN
Mar 21, 2013 07:22 AM
mikec410
Aerostar
Mar 28, 2011 03:53 PM
JefFZ6
Nov 16, 2007 11:31 AM
