speedometer calabration????????
Old Nov 27, 2001 | 11:08 PM
fordfan4fun's Avatar
fordfan4fun
i have a 1995 f-150 that has the digital odometer just fooling around i healed the reset button in and turned the key to the on position and the speedometer went all the way over to 90 m.p.h and back and read E 08 97 so like a dummy i pushed the reset button again and it read 972CAL dose anyone have any idea what this is? or dose? thanks in advance.
Old Nov 28, 2001 | 12:21 AM
niteowl7's Avatar
niteowl7
Yes, E 08 97 means that you can still recalibrate 8 times before needing to purchase a new cluster to recal again (8 is maximum, so it has never been recal'd) 972CAL is the conversion factor (97.2 minus the decimal point) that the computer uses based on a signal from a sensor on the ring gear (rear axle). 972 is the stock conversion factor for the stock 235x75x15 tires. If you have much smaller or larger tires, that number needs to be changed for your speedo to read correctly.
What bothers me is that you should not have been able to get to that code without the PSOM connector wire being grounded. That wire is located under the glove box just about center.
You can get a full explaination of how to recal by doing a search on "speedo recal" here on this board. In several of the posts, that info is there.
Hope this helps
'93 F150 XLT Supercab
5.0, AOD, K&N, Gibson
Old Nov 28, 2001 | 04:58 AM
93bigbronco's Avatar
93bigbronco
you can get the code without the wire being grounded, you just cant change the code unless the wire is grounded
Old Nov 28, 2001 | 05:04 AM
niteowl7's Avatar
niteowl7
Ah...thanks for the correction.
Old Nov 28, 2001 | 08:40 AM
Gates's Avatar
Gates
charlie c
May 2, 2015 07:47 AM
Ericwlod
6.7L Power Stroke Diesel
Sep 10, 2011 09:35 PM
broken wire
Sep 29, 2006 06:25 PM
leeiwonfan3
Jun 21, 2004 07:37 PM
pug2775
Aug 14, 2002 09:36 AM
