Any help would be appreciated!
Old May 15, 2017 | 03:03 PM
AllaboutMPG's Avatar
AllaboutMPG
Originally Posted by Jethro Bo
Swapped out the valve cover harness with a new one problem solved. So I guess a continuity test on the old one was a bad test but I know I did it right not sure if you can trust the test thanks guys
And thanks for letting us know what fixed it. All back together and on the road??
Old May 15, 2017 | 03:26 PM
Jethro Bo's Avatar
Jethro Bo
Trailering
Originally Posted by andym
When you do the injector re-installation, make sure you are following the correct procedure. It's not just a remove/reinstall.
http://www.riffraffdiesel.com/conten...structions.pdf
To those instructions, I would also add hot-torquing the injectors on installation. There are a few recent threads in here discussing this.
Righteous Andym. I just glanced over it. Hopefully it describes what hot-torquing is. I've never heard of it.
Almost, I have to tighten down the driver side vc bolts and pit the induction back on. Then good to go. All codes are gone!!
angel thepvong
Aug 11, 2017 01:12 PM
Zachsquatch
15
Aug 2, 2016 02:12 PM
fordzilla01
21
Dec 4, 2014 07:39 AM
catpwr1
May 21, 2012 06:09 PM
aocabrown
20
Jan 4, 2008 11:06 AM
