Hello all, I recently had a mechanic replace the turn signal switch on my 86' XLT Lariat, auto, w/tilt. Ever since the switch was replaced the fuse blows when the signal is used. He says one of the two springed contacts are arcing/grounding out. I need an exploded view/schematic of the collumn just behind the steering wheel if anyone has one. Also there's a small metal shim that fell out during disassembly of the collumn when the signal switch was removed & I can't figure out where it goes. It's about 1/8" X 3.5" long & rectangular. Suggestions? Thank you!
Reason: Adding details to my description of the problem
