harmonic balancer - visually different?
Old May 10, 2017 | 10:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D9TZ-6316-B .. 460 Harmonic Balancer-Use with external balance (has a weighted crank spacer) (Edit: Marked D9TE-EA): Block casting number D9TE-6015-AB
Some 1979 E250/350 & F150/350.
D4VZ-6316-A .. 460 Harmonic Balancer-Use with internal balance (Edit: Marked D4VE-AA) Block casting number: D1VE-6015-AB or A1B or A2B
1974/78 FoMoCo Passenger Cars & F100/350 / 1975/78 E250/350 / Some 1979 E250/350 & F150/350.
No: 460's in F100's after 1976, in cars after 1978, in 1979 F150's sold new in CA
Originally Posted by somethingclever
Bill is claiming they are different.
I'm not claiming the balancers are different, FoMoCo is.
These part numbers/applications were typed directly from the 1973/79: Ford Passenger Car & F100/500 Series Truck Parts Catalogs.
Since most FTE members don't have parts catalogs, I'm the messenger, typing the info from them.
1928 thru 1989 car & truck parts catalogs are available on C/D's from hipoparts.com
Old May 10, 2017 | 10:46 AM
JP3's Avatar
JP3
Holy crap that's rich!
You basically call me a liar and that my knowledge is BS and then say "Well, it wasn't me, it was FomoCo".
Stick to reciting crap from your parts catalogs and refrain from telling others that they are full of crap because you clearly have no clue outside of what you read in a book.
Old May 10, 2017 | 10:54 AM
meangreen92's Avatar
meangreen92
Ford says they're different, and I believe them. However, perhaps they're not so different that they can't be interchanged.
The 302/5.0 also had its traditional imbalance spec changed a year or two later.
Old May 10, 2017 | 05:28 PM
somethingclever's Avatar
somethingclever
[QUOTE=NumberDummy;17178162]I was a Ford parts guy for 35 years, so I know what I'm talking about.
Bill,
I am confused. You very clearly said that that others were wrong and that the balancers are different when responding to a question if they are interchangeable?
You responded in red and said the info that was given by someone else was crap and incorrect.
Please inform us what makes this response crap and incorrect which you felt necessary to say.
Old May 12, 2017 | 04:27 PM
PapaBearYuma's Avatar
PapaBearYuma
Went to the UPS store and picked up my care package from Summit. The Dorman harmonic balancer is actually spec'd for 80-95, but appears identical to the one I took off. I installed it today, and it seems fine.
I also bought a timing tape. The scale is a hair off, but I centered it at 14 degrees BTDC. Next time I break out the timing light, I'll take another looksie.
GeneGregory
May 12, 2015 05:50 PM
1999stroke
Jan 13, 2014 03:35 AM
Michael Hoskins
Apr 20, 2013 10:36 PM
oldmansimek
Sep 23, 2011 11:50 PM
jetblack06
Feb 12, 2010 07:42 AM
