Hazard Lights Not Working
Old May 8, 2017 | 12:28 PM
1993 ford's Avatar
1993 ford
I have a 1993 F-250 with a 7.3 non turbo and the hazard light don't work when I hit the button on top of the steering column to turn the hazard light on they don't come on and I can not use my blinkers until I hit the button to turn them off I have checked fuses. What could this be thanks
Old May 8, 2017 | 01:19 PM
madpogue's Avatar
madpogue
It's normal for the turn signals not to work when the hazard switch is closed. That's how the multi-function switch works.
The hazards use a separate flasher from the directionals. The directional flasher is the one you can see in the fuse box when you remove the cover. The hazard flasher is directly behind it, installed from the other side of the fuse box. It's a TIGHT fit, but you can get your hand up in there and remove it. Try replacing that first. This is, of course, assuming you've already checked and ruled out the fuse.....
Old May 8, 2017 | 06:00 PM
1993 ford's Avatar
1993 ford
Ok thanks could you look at the thread I just posted and help me out with that more worried about that right now
JohnBOV43159
Aug 5, 2018 07:59 AM
hayden01
Electrical Systems/Wiring
15
Oct 25, 2017 05:39 PM
BuckHammer
15
Mar 11, 2011 07:51 AM
pedrorairez
23
Jan 22, 2007 09:21 PM
Peganit
Aerostar
Feb 28, 2004 10:17 AM
