What did you use to do such a neat precise job of cutting it in two?
As a pressure vessel, it has to be working rated well above 500 PSI strength, to allow safety margin for the high pressure relief valve to blast open if the HPCO doesn't drop the clutch out in an overpressure failure mode. So the wall thickness is up there!
Reason: Edited so "B-a-l-l-s" would pass the word blocker
