6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Chirping Noise? Easy, Low Tech Fix!
Old Feb 8, 2016 | 03:04 PM
turbinefix's Avatar
turbinefix
I've been having this "belt-like chirping noise" from under the hood lately so I immediately assumed a tensioner pulley or one of the other pulleys. It only happens occasionally and while accelerating. The last time it chirped, I happened to be turning off my AC and presto...no more chirp! I turned out to be the AC compressor clutch. If you're hearing that annoying chirping sound, it's worth a try to check the AC clutch.
Old Feb 13, 2016 | 06:30 PM
craftsmangary's Avatar
craftsmangary
If it's making noise with the A/C on then the noise is the compressor, not the clutch, when you turn the A/C off the clutch becomes a idler pulley. So with the A/C on the bearing is not turning.
We87
Jul 31, 2019 07:03 PM
Jeff W.
Nov 30, 2014 06:35 PM
yusko40
1997 - 2003 F150
Mar 3, 2012 11:37 PM
spwilliams
Sep 11, 2011 10:49 PM
skilife17
1997 - 2003 F150
Jun 25, 2007 08:56 PM
