Sponsored by: Auxito
Brake Issue
Old May 6, 2017 | 12:23 AM
Nathanderthal's Avatar
Nathanderthal
Brake Issue
My son came home this evening saying that the brakes on the truck (1997 F150 2wd) were bad. I thought that was a little weird as the pads have 80% life, and the rotors were new when I changed the pads. The brake pedal seems a little spongy lately, but I hadn't noticed any problems. I took it for a test drive and only made it about 50 feet before I pulled back into the driveway. When I backed out I didn't notice anything. As soon as I put it into drive and began to move forward I heard a grinding noise. When I applied the brake the brakes activated with a loud banging noise and locked up, bringing the truck to a dead stop. When I let off the brake pedal the brakes stayed locked up. When I applied the brake again, same banging noise and lock up. Any ideas?
Old May 6, 2017 | 12:45 AM
Nathanderthal
Eureka! I found the problem. One of the caliper bolts on the passenger side came loose and the caliper is rubbing the inside of the rim. $6 fix.
Old May 6, 2017 | 09:45 AM
alloro's Avatar
alloro
With only 22 minutes between your first post and your eureka moment doesn't give us here much time to show off our stuff. Glad it was an easy fix.
75kona
Apr 16, 2018 04:38 PM
MiamiPSD
Feb 8, 2014 08:55 PM
FarmingFord
Mar 31, 2009 11:50 AM
akford351
Dec 7, 2006 11:25 AM
mbnv992
Nov 30, 2004 11:37 PM
