Help with part ID
Old May 5, 2017 | 12:06 PM
Gambler72's Avatar
Gambler72
Help with part ID
Hey guys..... just picked up a 79 F250 super cab.... looking it over I see this is leaking... appears to be a part of the tranny cooler? What is it so I can replace it? Thanks!!!
Old May 5, 2017 | 01:57 PM
DB429SCJ's Avatar
DB429SCJ
Looks like some type of sending unit. What do those wires connect to ?
Old May 5, 2017 | 02:13 PM
moreratlessrod's Avatar
moreratlessrod
On my '79 F250, that white wire connected to an aftermarket oil pressure gauge. The gauge didn't work and I later found an open splice in the wire resting against the inner fender. Not sure if that helps any. Maybe someone else can offer some input.
Old May 5, 2017 | 03:10 PM
lasermike's Avatar
lasermike
My guess is it's a temp sender for the transmission. If you don't need it, you can bypass it but not the cooler!
Michael
old-rodder
Jun 15, 2010 06:08 PM
Brown Falcon
41
Jan 28, 2010 03:11 PM
lucky no. 7
Aug 9, 2008 07:53 PM
gdfrick122
Dec 5, 2007 08:54 PM
body9599
May 14, 2004 08:33 PM
