finished most of the work on my '84 F150
Got the truck last summer. Gray paint with burgundy interior. Went through her mechanically, electrically, did some bodywork and a paint job, had the interior re-done and just finished putting in a 4bbl carb and new intake and exhaust manifolds.
Write up and pics here:
https://www.ford-trucks.com/forums/1...manifolds.html
Pretty sure they are the Bushwacker Extend A Fender flares. ABS plastic.
On the rear, the panels above the wheels were damaged, so the flares were a relatively cheap fix (but still expensive). Had them coated with bedliner along with the rest of the bottom of the body and it came out great! Wasn't sure if I was going to like it, but the added black and the texture of the bedliner work well look good.
The panels and the kick panels came from Bronco Graveyard. Good quality parts. The kick panels are especially nice since they have the molded pockets.
1987-1991 Ford Bronco and F-Series Truck Door panels-No power, Black-Broncograveyard.com
1980-1991 Ford Bronco and F-Series Truck Door kick panels-Dark Gray - Broncograveyard.com
I've got a Dentside supercab, but these might work for that, too, as the second row will tilt and slide...
Got mine from someone off Craigslist in Phoenix.
https://phoenix.craigslist.org/cph/p...321618831.html
We ran two lengths of 1" steel tubing bolted to the floor and the seats and center console bolted to the tubing.
