1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fender Flares and Line-X
Old 09-17-2010, 08:31 PM
cdrmotorsports's Avatar
cdrmotorsports
cdrmotorsports is offline
So I'm getting my to-do list in order. I want to Line-X the rocker, inside door edges, and maybe underneath the truck (all in black). I will also be adding a set of Bushwacker fender flares as well. Should I Line-X then as well? Would it look ok? Would it adhere? Should I just leave them black and not bother Line-Xing them? I don't know what would look better. Also, if I got the pocket style fender flares would they be able to be Line-Xed or should I just stick with the smooth styled ones? Decisions, decisons!
Old 09-17-2010, 09:26 PM
kabcpapc's Avatar
kabcpapc
kabcpapc is offline
In my opinion I would not Line-X the fender flares because the Line-X is a rough surface. It will be more prone to collect dirt and mud and therefore will be harder to clean. Either paint them to match or contrast the truck or leave them black.
Old 09-17-2010, 10:51 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
I def think you should get them Line-X, for the very opposite reasons. I think the coating will hold up better than paint! I had my older Toyota Tacoma's whole exterior sprayed with a no-name liner and it worked/looked amazing~ VERY EASY TO CLEAN!!!
I went out and had my pocket fender flares color matched and I wish I had left them stock or had them Line-X/etc! I may still do exactly what you are thinking of doing with the lower body molding and such!
if you get a price quote, please share it with us~~
Old 09-17-2010, 11:05 PM
LBF's Avatar
LBF
LBF is offline
styrofoam cooler
When I got my '97 F150 sprayed with Line X they had a styrofoam cooler on display that was also covered - so I don't think your fender flares will be a problem.
Old 09-19-2010, 04:45 PM
cdrmotorsports
Thanks for the opinions guys!
Old 09-19-2010, 07:58 PM
BobbyDiesel71
If you get it done, please post pics!
Old 09-20-2010, 03:21 PM
cdrmotorsports
I will be sure to. It might be a little while I have to sell one of my toys so I can pay for my fender flares, Line-X, DP Tuner, gauges, and 4.30 gears that I'm about to do.
Old 09-20-2010, 04:12 PM
Grumpy Moose's Avatar
Grumpy Moose
Grumpy Moose is offline
Go for it. If I had enough money, I would have had my entire truck sprayed!
Before:
After (Bed, side caps, front & rear bumbers, tailgate, and headache rack):
Old 09-20-2010, 04:56 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
I wonder how much more the entire truck would weigh sprayed. They estimated the bed liner in my last truck at 200lbs of Rhino. It's pretty dense. Ask the dealer.
Old 09-20-2010, 06:14 PM
Grumpy Moose
Yikes, I didn't realize the stuff was that heavy. I'd bet I've probably got 400 lbs of the stuff on mine. I need to take it to the scales again to see.
Old 09-20-2010, 07:18 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
linex
weight only accounts for 5% of rolling resistance. therefore spraying it will still be a good thing.
Old 09-21-2010, 11:37 AM
cdrmotorsports
Looks good grumpy!
Old 09-21-2010, 12:26 PM
ChargersFanInCO
Ford claims a 1% drop in mileage for every 100lbs of additional weight carried. It in the diesel supplement that comes with the 6.4 in the section covering how to get the best mileage.
Old 09-21-2010, 01:46 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Where did you pull that spec. out of? Rolling resistance is proportional to the normal force (weight) on the tire.
Old 09-21-2010, 02:05 PM
EODguyJake's Avatar
EODguyJake
EODguyJake is offline
Fulltime INFIDEL!
I vote no fender flares, just spray the rig. My front and rear bumpers, steps, rockers (inside the doors), grille guard, and body line all the way around (to include the bottom of the tailgate) are all sprayed.
Quick Reply: Fender Flares and Line-X
