Stuck 292 starter
Old May 2, 2017 | 08:06 PM
Fryintires6208's Avatar
Fryintires6208
Stuck 292 starter
When I went to start my 62 F100 292 a while back, the starter wasn't cranking correctly, and instead it would just produce an awful grinding sound. Long story short, I pulled all the bolts on the starter, but it won't come off the engine. I've pulled and pried and smacked it with a mallet till the cows came home but she still won't budge. Any help would be greatly appreciated. Thanks!
Old May 2, 2017 | 08:38 PM
resonateur's Avatar
resonateur
Sounds like the bendix drive gear is jammed into the ring gear. Take off the inspection cover under the bellhousing and try to rotate the motor with a prybar on the ring gear to unlock it. Or turn the motor over with socket and breaker bar on the crankshaft balancer bolt. You may need a new ring gear if the teeth are damaged.
79FORD-DENT
Jan 26, 2011 11:49 AM
GregAlex47
Aerostar
May 30, 2010 10:16 AM
75highboy
16
May 15, 2009 11:44 PM
jermyjudge
Mar 25, 2008 02:07 PM
gatesj
Dec 27, 2002 05:47 PM
