Load-O-Matic Carburetor/Distributor
Old 04-30-2017, 03:55 PM
69-er's Avatar
69-er
69-er is offline
I have discovered my 67 240 engine has a Load-O-Matic distributor but the carb apparently is a conventional style with no spark control valve. It has a blank hole but no threads for the control valve.
I have a few options: Find a Load-O-Matic carburetor, modify it to Load-O-Matic specs or find a conventional distributor with mechanical advance. Seems like finding a distributor would be easier.
But first, I would like to know if it's possible to determine what the truck originally came with. That would have a bearing on what my next step would be.
Any Load-O-Matic experts out there?
Old 04-30-2017, 04:51 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Most people recommend ditching the loadomatic distributor. They used a different vacuum arrangement, venturi vacuum, above the throttle plates, some kind of metered deal. A regular carburetor will not work right. Even with the correct carb, it never worked all that great. They tended to fall flat on their face, especially if they got out of tune or high miles, I'd imagine. Not one of FoMoCo's better ideas.
Old 04-30-2017, 05:14 PM
69-er's Avatar
69-er
69-er is offline
True on that. Another reason maybe to go with a 68 and up distributor with dual advance. It seems that 67 was the last year for LoM so I'm guessing the truck came with it.
Old 05-01-2017, 03:57 AM
KOT390's Avatar
KOT390
KOT390 is online now
I think it would be a toss up myself. I can't imagine why your 67 couldn't have come with dual advance also. Both distributors were available from at least the early to mid 60's. You may be right on 67 be the last year for LoM though.
KOT390
Old 05-01-2017, 08:15 PM
69-er's Avatar
69-er
69-er is offline
Funny, both versions of the dist are available for the 67. But the differences are "Without Thermactor emissions" for the LoM and vise versa. Don't know what an air pump would have to do with it! I'm gonna get the dual advance dist. It's more conventional and I'm much more familiar with "normal" stuff. At $40, it's cheaper than finding a decent LoM carb.
Thanks for everyone's guidance.
Old 05-02-2017, 06:46 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Kaliforny emissions
Old 05-03-2017, 06:53 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Buy a Dizzy off a little newer 240 so it isn't a loadamatic.
Old 05-03-2017, 08:01 PM
69-er's Avatar
69-er
69-er is offline
Got one coming in tomorrow.
HillBillyBuddha
01-27-2019 03:19 PM
Markrichter
05-10-2018 06:28 PM
Rusty_S
01-07-2015 10:59 PM
Gearheadjo
06-06-2008 01:27 AM
Me and My F100
09-11-2003 01:03 PM
Quick Reply: Load-O-Matic Carburetor/Distributor
